Not able to use "." in a Tex box
I have tried searching in the help doc about this but I did not find anything.
I am trying to use a text box and have 1. inside of it, but it keeps erasing the period "." I am just trying to make a few text boxes to make it look like a list.
Example below
1.
2.
  1. I tried using a f(x) and then using quotation marks, and it would work, but if I reopened the properties it automatically converts the text widget back to a Text type and removes the period "." at the end. The same result happens if I use GetPhrase() as well, it will automatically change it back to a Text type and remove the period.
I am able to put two periods ".." at the end and it works, but that is not what I am looking for.
Is there a reason that the program would restrict a single period in the basic Text widget?
PS. Multiline widget will not work because of the spacing.
I have tried searching in the help doc about this but I did not find anything. I am trying to use a text box and have 1. inside of it, but it keeps erasing the period "." I am just trying to make a few text boxes to make it look like a list. Example below 1. 2. 3. I tried using a f(x) and then using quotation marks, and it would work, but if I reopened the properties it automatically converts the text widget back to a Text type and removes the period "." at the end. The same result happens if I use GetPhrase() as well, it will automatically change it back to a Text type and remove the period. I am able to put two periods ".." at the end and it works, but that is not what I am looking for. Is there a reason that the program would restrict a single period in the basic Text widget? PS. Multiline widget will not work because of the spacing.
I wanted to follow up that this has been corrected in VTScada version: 12.1.29 and newer.
Thanks for letting me know Dave.
Could not find that in the notes but it's good to know that it's been fixed in the newer version.
Thanks for letting me know Dave. Could not find that in the notes but it's good to know that it's been fixed in the newer version.
103
