566
1.99k
29
181
hilldc posted Dec 11 '23 at 1:32 pm
Fairly new to VTScada and I need help setting up certain tag to pull from a weather station (Columbia 420) we have.
The station keeps a running total up to 10 inches before rolling back to 0 inches. I would like to display rainfall today but the reset back to 0 has me stumped as to how to setup that tag to account for the rollover which could happen in the middle of the day.
Thanks in ad
recent by cardsfan  ·  Dec 13 '23 at 1:02 pm
224
jroc11 posted Dec 5 '23 at 4:22 pm
Im currently trying to find out a way that i can make a digital tag that goes from on to off and off to on every 15 minutes or so. Is there any suggestions on what the best way to do this is. I will be pairing this tag with another one in an expression to trigger a multi write tag every 15 minutes while the day is between certain times. Any suggestions help! Thanks
287
So i have an analog calculation tag that is logging data based upon the whole day. i need to to grab two values from this day, these values are from 6am- 2pm and 5:15pm-2am. What is the best way to do this? i have tried using totalizers, logging tags, triggers, history stats, but no luck. I have two digital tags setup for each shifts. They output on or off depending on if the current time is in-b
recent by jroc11  ·  Nov 30 '23 at 4:42 pm
619
8
We're familiar with most SCADA software, but still learning VTSCADA. We are used to the flexibility of script to do things that native symbols and widgets do not do.
Right now, we are trying to configure a button that when clicked, will perform:
TagA = TagB. (where TagA and TagB are Analog Values)
Searching through the help files, we can only find "button" style widgets in
recent by cardsfan  ·  Nov 19 '23 at 1:55 pm
131
I need to move history from one tag to another. For reasons, I need to remove one tag and replace it with another but I need to keep the history, and it's on about 80-100 tags.
Does anyone have a strategy for migrating data from one tag into another in bulk fashion? Exporting the data, massage the date and timestamp and do the CSV import would take much too long.
Thanks.
recent by Michael  ·  Nov 17 '23 at 5:52 pm
386
kurtisjackson posted Nov 14 '23 at 4:13 pm
I'm looking to see if there are any tools that can "skinny" down historical data. We are now supporting some hosts that had overly high poll rates when they were commissioned, the historian subsequently got bloated and is now using up too much HDD space.
Are there any tools available that can go back and remove swaths of data, or perhaps replace a 10 min span of 1 second data with a single a
recent by Michael  ·  Nov 17 '23 at 4:16 pm
84
I'm trying to add a new OPC UA client :
endpoint url : opc.tcp://10.247.10.2:4840
allow unsecured connections is on
authentification is Anonymous
inside the client certificate I created a new certificate
In the server certificate I saw an untrusted certificate and added it into the trusted ones
Now when I add this OPC UA client, the values says : 514 - Server Certificate subj
88
gtuvar posted Nov 11 '23 at 5:38 am
How to access a dictionary whose variable is created in one page as a network value in another page? e.g storedpumpdata is a network value variable and it is registered in X page. now I want to access storedpumpdata via dictionarycopy function in another page.
103
hienho posted Nov 9 '23 at 1:04 am
Hi everyone, How to get Value from SQL to VTScada. I tried to use SQL Query Driver but failed
654c2fed8f12d
135
saintatticus posted Oct 30 '23 at 3:50 pm
Hello, I have configured a Camera tag for my system but I would like to also configure an Alarm tag to alert the users if connectivity to that Camera URL is lost. Currently, if that connectivity is lost, the video stream just appears "frozen" in the dashboard no matter how much time passes -- i.e., showing the last displayed frame as a still image. But this is the same observed behavior if the
137
Tames posted Jul 20 '23 at 9:47 pm
I have tried searching in the help doc about this but I did not find anything.
I am trying to use a text box and have 1. inside of it, but it keeps erasing the period "." I am just trying to make a few text boxes to make it look like a list.
Example below
1.
2.
I tried using a f(x) and then using quotation marks, and it would work, but if I reopened the properties it automati
recent by Tames  ·  Oct 30 '23 at 2:33 pm
188
I have successfully received email alarm notification and sms alarm notification on my smartphone through Twilio with no additional Twilio configuration other than a Twilio phone number. Phone Calls are not being made.
I'm really hoping there is not additional programming to be made on the Twilio side.
Is there more programming than what was advertised to make call outs work, or should c
145
Currently we have a SCADA system working, but we want to change the IP of the devices in site (Modbus Compatible Device). When we do that, we will have to do port forwarding in the router. Instead of that, is there any way in VTScada to associate the IP Address of the device? in this way, when we change in site the IP Address, we only have to change the value in the SCADA directly inst
653a5cae0bec3
92
I am trying to grant consent for OAUTH 2.0 for VTScada to use an MS365 email account to send and receive. When I click on "Consent" in the Review and Modify Security Settings window, the dialog "Obtain Consent for Grant" opens and just says "Operation Status: Consent Operation Running" but nothing else happens.
No browser window opens as mentioned in
https://www.vtscada.com/help/Content/D
1 ... 78910111213 ... 29
