Retrieving logged data for use in calculation tag
I'm wanting to retrieve logged data for use in a calculation tag expression. Basically "[tagNamevalue] @ [datetime]". Any way of doing this?
I'd also like to be able to generate averages and min-max values based on a user defined period.
I'm wanting to retrieve logged data for use in a calculation tag expression. Basically "[tagNamevalue] @ [datetime]". Any way of doing this? I'd also like to be able to generate averages and min-max values based on a user defined period.
edited Jun 22 '23 at 6:03 pm
If you wanted to write a custom tag type for this, you would probably use the GetTagHistory() function but it is script only and won't run in a standard calculation tag.
Help on GetTagHistory: https://www.vtscada.com/help/Content/Pro_Functions/GetTagHistory.htm
If you want to do this without custom script, you can setup the built in REST API and use the JSON/XML driver to query the historian on localhost and return the response (JSON format) to one or more tags. It's a bit of a workaround but isn't very difficult to configure.
If you wanted to write a custom tag type for this, you would probably use the GetTagHistory() function but it is script only and won't run in a standard calculation tag. Help on GetTagHistory: https://www.vtscada.com/help/Content/Pro_Functions/GetTagHistory.htm If you want to do this without custom script, you can setup the built in REST API and use the JSON/XML driver to query the historian on localhost and return the response (JSON format) to one or more tags. It's a bit of a workaround but isn't very difficult to configure.
