Droplist widget write into Context Tag Property?
Is it possible to make the droplist widget write to a property of a context tag? I haven't been able to successfully change the properties this way of a Context tag this way. I can always set up a hotbox an operator can right click and edit properties in this way. But the most user friendly/ optimal method for data governance would be this droplist widget.
Another way would be to create a separate memory tag and link the droplist widget. I was just trying to avoid this method for consistent hierarchy with my other user-defined tags.
I'm thinking one way might be to use the linked tag property feature in the widget, but I haven't been able sucessfully use this feature either.
Thanks for any ideas smile
Is it possible to make the droplist widget write to a property of a context tag? I haven't been able to successfully change the properties this way of a Context tag this way. I can always set up a hotbox an operator can right click and edit properties in this way. But the most user friendly/ optimal method for data governance would be this droplist widget. Another way would be to create a separate memory tag and link the droplist widget. I was just trying to avoid this method for consistent hierarchy with my other user-defined tags. I'm thinking one way might be to use the linked tag property feature in the widget, but I haven't been able sucessfully use this feature either. Thanks for any ideas :)
47
