Recipe Start Batch
Hi,
I have multiple recipes that are configured in my VTScada application. I would like these recipes to all start together with a common start request.
The two questions i have are...
  1. Can a single bit start multiple recipes (Send values to PLC) ?
    I understand a single bit can be the main source but the recipe start button needs to be linked directly to the recipe book.
    Example... Common Start Button is activated (1) All recipe book start batch tags are activated.
  2. Can you disable the Start Recipe pop up screen? as if the first question is achievable i do not want 5 + Batch number pop up screens appearing.. it would be nice to not have this feature turned on.
Separate side note (query)... is there a way to activate a pop up screen by a tag value? without having to use a page button?
Thank you for your time in advance.
Joe.
Hi, I have multiple recipes that are configured in my VTScada application. I would like these recipes to all start together with a common start request. The two questions i have are... 1. Can a single bit start multiple recipes (Send values to PLC) ? I understand a single bit can be the main source but the recipe start button needs to be linked directly to the recipe book. Example... Common Start Button is activated (1) All recipe book start batch tags are activated. 2. Can you disable the Start Recipe pop up screen? as if the first question is achievable i do not want 5 + Batch number pop up screens appearing.. it would be nice to not have this feature turned on. Separate side note (query)... is there a way to activate a pop up screen by a tag value? without having to use a page button? Thank you for your time in advance. Joe.
49
