Adding a comma before last digit
I've got a tag numeric value that I need to add a comma before the last digit.
For example, 837 would need to be formatted as 83,7. The value 49837 would be 4,983,7. The value 7 would just be 7. This is how the customer wants to see the values on the screen. I know this will have to be formatted as a string but not sure how to go about it.
The CommaFormat looks to only add a comma per thousand and if I had the digits all separate, I could use the concat to add in commas, but I really prefer to not break down each digit of the numeric values b/c there are a LOT.
I've got a tag numeric value that I need to add a comma before the last digit. For example, 837 would need to be formatted as 83,7. The value 49837 would be 4,983,7. The value 7 would just be 7. This is how the customer wants to see the values on the screen. I know this will have to be formatted as a string but not sure how to go about it. The CommaFormat looks to only add a comma per thousand and if I had the digits all separate, I could use the concat to add in commas, but I really prefer to not break down each digit of the numeric values b/c there are a LOT.
This will return a string only so it wont be able to trend like an analog, but here you go.
concat(SubStr([..], 0, (StrLen([..]) - 1)), ",", SubStr([..], (StrLen([..]) - 1)))
This will return a string only so it wont be able to trend like an analog, but here you go. concat(SubStr([..], 0, (StrLen([..]) - 1)), ",", SubStr([..], (StrLen([..]) - 1)))
How Many Time Have You Read though every function, and the source debugger?
edited May 7 '24 at 5:57 pm
244
