How to write multiple functions into one *.src file
In VTScade it is possible to define your own functions.
Edit AppRoot.SCR where the file with functions is defined.
Then in the file for example NewFunctionName.SRC you write a function.
This works correctly for me if there is only one function in the file, but when you add a second one it says that you are using the used variable.
You rename the variable and it ends up that the MAIN block is already defined.
How to write multiple functions into one *.src file In VTScade it is possible to define your own functions. Edit AppRoot.SCR where the file with functions is defined. Then in the file for example NewFunctionName.SRC you write a function. This works correctly for me if there is only one function in the file, but when you add a second one it says that you are using the used variable. You rename the variable and it ends up that the MAIN block is already defined.
edited Feb 3 '25 at 5:20 pm
92
