Using VTSCADA To Send Data To Create A Work Order In Maximo
Hello, I am new to using VTSCADA but have experience with SCADA software in the past. For our application, we would like to utilize VTSCADA to create data driven maintenance packages utilizing Maximo to create Work Orders.
An example of this application is:
HVAC filter dp is monitored and there is currently an existing job plan in Maximo to do the PM to replace the filters. VTSCADA would have a trigger associated with dp going out of range, and once this threshold is met, VTSCADA sends a script in the required format for Maximo to automatically generate a WO using existing job plans.
This kind of system is being utilized by our facilities with other software, examples being PLC's, and we already have the Maximo side of it figured out. We know the requirement for the data to come in, in JSON format.
The question is, how do we get VTSCADA to send the necessary data to an already established URL. I know VTSCADA can send data via SMS and email. Has this function been used before? If so, how did you set it up? Or is there a generally agreed upon method of sending data to URL's?
Hello, I am new to using VTSCADA but have experience with SCADA software in the past. For our application, we would like to utilize VTSCADA to create data driven maintenance packages utilizing Maximo to create Work Orders. An example of this application is: HVAC filter dp is monitored and there is currently an existing job plan in Maximo to do the PM to replace the filters. VTSCADA would have a trigger associated with dp going out of range, and once this threshold is met, VTSCADA sends a script in the required format for Maximo to automatically generate a WO using existing job plans. This kind of system is being utilized by our facilities with other software, examples being PLC's, and we already have the Maximo side of it figured out. We know the requirement for the data to come in, in JSON format. The question is, how do we get VTSCADA to send the necessary data to an already established URL. I know VTSCADA can send data via SMS and email. Has this function been used before? If so, how did you set it up? Or is there a generally agreed upon method of sending data to URL's?
VTScada has been successfully linked to Maximo, but it requires custom scripting to accomplish this.
The HTTPSend function in VTScada can be used to do a JSON POST to the Maximo DB to create a work order.
Data from Maximo can also be read by VTScada using the ExecuteQuery function in the ODBC Manager Library.
This would let you display a list of work orders and their status in a VTScada page..
VTScada has been successfully linked to Maximo, but it requires custom scripting to accomplish this. The HTTPSend function in VTScada can be used to do a JSON POST to the Maximo DB to create a work order. Data from Maximo can also be read by VTScada using the ExecuteQuery function in the ODBC Manager Library. This would let you display a list of work orders and their status in a VTScada page..
181
