183
1.26k
16
50
Jerry posted Aug 11 at 3:39 pm
I created a SerialStream in the screen's script, and the serial port can open successfully. But when I use Sersend to send data, the data isn't sent immediately—it only gets sent when I switch screens or close the project. What method should I use to force flush the send buffer?
Here's the script I tested:
Main [
Return(Self);
If Watch(0,Creat);
stream
51
hilldc posted Jun 29 at 3:33 pm
I am using the Training Simulator 12.1 app to simulate a wastewater lift station as a demo for our staff. Is there a way to configure the "PLC" settings so the pumps alternate in auto instead of running simultaneously?
Thanks
recent by hilldc  ·  Jun 30 at 4:53 pm
51
What is more efficient, scope calls with more then 1 reference, or scope call to variable.
What is the system weight on scope functions.
For Example
IF Watch(1, Scope(Root, "Run Status")\Value);
Value = \GetPhrase(Scope(Root, "Run Status")\DisplayValue);
OR
RunStatusVariable;
RunStatusVariable = Scope(Root, "Run Status");
IF Watch(1, RunStatusVariable.Value);
100
Martin posted Apr 9 at 4:49 pm
I am creating a project to track production of equipment for multiple customers at one shop. I am using parameterized pages.
This includes a Level 1 Page for Customer Selection, Level 2 page for Equipment Selection, and Level 3 that includes a widget (String entry for Equipment ID, and Droplist for Process Status for that piece of equipment). I have also setup a Dashboard Page to see all Leve
69d7c40b9a5a1
recent by cardsfan  ·  Apr 11 at 2:53 am
54
I have a 4-monitor system with 4 separate VIC sessions running. Is there a way to configure the parameters of a VIC session shortcut to display in a specific monitor?
Thanks!
200
beno posted Jan 7 at 5:59 pm
Brand new to VTSCADA but not SCADA platforms.... (I plan to sign up for either remote or in-person training ASAP).
I have a noisy alarm and rather than just bump the setpoint, I'd like to understand what the tag is reporting.
Here are the tag details as exported from the Record Details pop up box.
Name Rockwell\Alarms\CommsLoss
Description PLC Loss of Comms
recent by Boonz  ·  Mar 9 at 4:32 am
100
hilldc posted Mar 8 at 2:43 pm
I'm getting about an hour flatline on trends which started with the time change this morning. I have checked times on all servers to make sure they updated and match. Any suggestions? Thanks
69ad8b0a26d9b
recent by Boonz  ·  Mar 9 at 4:24 am
129
I have been searching high and low for a resolution for the easiest way to copy one widget/group from one screen and pasting it into a different screen in the same exact coordinates. What am I missing here? I know I can go in and edit the coordinates once I paste it, but there just HAS to be an easier way. Please help a noobie.
82
Como faço para configurar o botão "relatórios" para gerar automaticamente um relatório pelo HDV, sem precisar acessar a página de Relatórios? Estou com dificuldades.
Como faço para configurar este botão (com as tags que precisam ser exportadas) para que eu possa simplesmente clicar nele?
6968f66d9569c
132
Hello everyone,
We are planning an upgrade for one of our older site servers running a [mention your specific platform, e.g., Vantage, Citect, etc.] Historian. The machine currently uses a standard SATA hard drive, and we are looking to significantly improve data access times and overall system responsiveness.
We have identified a https://serverorbit.com/solid-state-drives-ssd/sata-6gbps-
143
J_Hob posted Oct 2 '25 at 2:52 pm
I have created a HTML report page that interacts with my VT Scada application historian.
Does anyone know of a way that i can link my HTLM file (local to server) to a widget or screen?
e.g. Push button that opens the HTML.
Thank you in advance.
Joe.
125
Sukhmeet2810 posted Oct 1 '25 at 2:55 pm
I wanted to ask, can we still connect to the OPC UA Server or SQL Server (which is the VT Scada Server where tag history is stored) with the runtime licence only? I have heard software like XLReporter run with VT Scada without the needed Development Licence.
I know VT Scada stores data in its own historian, but is there with just the runtime licence - we can configure the Scada project to sto
1234 ... 10
