plinker
posted May 8 '25 at 4:25 pm
Attempting to connect to HiveMQ Cloud MQTT Broker which requires TLS. I've connected to other MQTT brokers that didn't require TLS with no issues. I've created an MQTT Client Driver and created a TCP/IP Port child. None of the TLS settings were successful so I download a pem file from HiveMQ, converted it to a crt file using OpenSSL and imported it to my PC but it does not appear in the list o
Jerry
posted Apr 21 '25 at 8:55 am
When the user looks at the trend curve, he wants to see the two identification lines of high alarm and low alarm, and when the user looks at the temperature for a period of time, he can clearly see whether the data is abnormal。
See picture
In subsequent versions, can the function of alarm identification of graphs be added?
Than you
Hello, I am new to using VTSCADA but have experience with SCADA software in the past. For our application, we would like to utilize VTSCADA to create data driven maintenance packages utilizing Maximo to create Work Orders.
An example of this application is:
HVAC filter dp is monitored and there is currently an existing job plan in Maximo to do the PM to replace the filters. VTSCADA would
Cicada
posted Mar 20 '25 at 12:35 pm
Can a VTSCADA Light application be a subordinate to a VTSCADA standard application?
azizi
posted Mar 21 '25 at 6:38 am
Hi all,
I'm implementing alarms in VTScada at a water treatment plant, but I'm facing some problems. I want to set up alarms to occur at certain threshold values and notify operators via email. But I'm not certain on how to correctly implement alarm priorities and ensure proper notification is being sent.
Here are my queries:
What's the best method for configuring alarm priorities in
J_Hob
posted Mar 19 '25 at 7:21 am
Hi All,
I am having an issue with a daily report that i have configured.
My understanding is that a daily report is a sum of the values accumulated for a each of a selected set of tags within the time period you specify.
Very simple i have four tags which values change approx. 4 times a day, in theory these values should be added together and displayed as a 'Daily Total'... Right?
Good Day,
This is very basic but I cannot find any information on it.
How do I pass a Tag Value to a script parameter?
Or
Can someone provide the best way to learn VTSCADA script?
ProPump
posted Feb 20 '25 at 4:15 pm
Need to enroll my users using SCADA to Entra Office 365, this creates a new profile at computer. Will users settings and licenses work afterwards? Same computer. SCADA was installed locally and will be on our network which creates a new profile for user.
Hi all,
I have an application in which each tag has a context folder with tags just for internal use. That is, tags that will be needed for some widgets but we don't need the final user, in this case, the operators to have access to them.
Is there a way to hide them from the list of tags but still have them do their job?
Thank you in advance.
Jerry
posted Feb 18 '25 at 9:25 am
When two VTScada servers are redundant, how to get the operational status of the primary and backup servers and then display them on the screen。
Thank you
Hi, Im wondering if there is a way to build one popup, and each time its opened, depending on what screen its on, if there is a way to assign a different UDT or tag for it to look at. For example, if i have 3 displays that all show flowmeters, can I use a single popup instead of creating 3 separate popups and just have the tags that it looks at, change based on the page its on??
Boonz
posted Feb 5 '25 at 5:21 pm
This would be a simple thing to add. Have a system properties that sets the default width of drawings pipes and lines. So you dont need to always change the width if you don't like the huge default size of pipe drawing tool.
Hi all,
In the tag browser, is there any way you can use an "or" statement to search for multiple tags at the same time?
With the upcoming flood of Win11 upgrades for fall 2025, what are the minimum requirements needed for VTScada version?
I want to use vtscada for a project for the first time.
There is 150 individual machines(workstation). Where we need install vtscada on each machine. Each machine would have around 50 tags. And need 1 server at control room where all the machines can be access. Beside that need remote access 1 user, alarm notification SMS EMAIL. Big Remote screen at plant floor.
Please help to s
Hello, I am trying to create a control screen on the left hand side that auto populates depending on what equipment is present on the main screen. So if we have 3 pumps on the main screen, the side screen should autofill with 3 pump start/stop button that correctly reference the names of the pumps.
Could anyone point me to a resource that would help with this setup?
Thank you.
Hey,
I am working on a project using Trihedral’s software & I could use guidance. I am in the process of configuring a few systems; but I am running into challenges when it comes to optimization and best practices. I want to hear from others who have had experience with this software.
What are some of your go-to tips for setting up efficient SCADA systems using VTScada? Anyth
Hello everyone! I am a new VTScada developer that needs some guidance. Here is my current challenge that I need help with:
Our team wants to set up a callout system using Twilio. I've got that part working in a test environment. The next step is setting up a page or widget or other method that allows operators to modify the roster without tag permissions. We want certain operators to be able
Maiza
posted Dec 26 '24 at 12:56 pm
I would like to know if it is possible to have remote access to the supervisory system through the domain/url without a VPN? I purchased a domain and hosting and I need to have my supervisory system on this domain, but I do not have a VPN. I would like to know if it is possible and also how to do this configuration because the SSL Connection video on VTScada's YouTube is out of date and some item
Maiza
posted Dec 30 '24 at 5:26 pm
I'm trying to access my application through remote access. I tried to do the procedure in the SSL video (https://www.youtube.com/watch?v=1DSan2ltzFg
) but without success. I'm using a domain (maizavitoria.com.br) and hosting. I'm getting an error with the SSL certificate in the manager. Where am I going wrong? Please help me. The Switch used is this one: PLANET FSD-503 (https://planet.com.br/p
