How do I read the variable in Swapped Float format in VTScada? Carel uPC3 via Modbus Compatible Device
How do I read this address from VTScada? I've tried all the Data Suffixes for Tag I/O Addressing but it didn't work. Below is the address "30001" in ModScan and its temperature reading. I've tried "30001/Float" but it didn't work.
I also tried to do it through BuffOrder but I didn't understand correctly how to set it.
66e47940293c9
66e479407249f
Regarding the "Coils" they are working perfectly.
66e4799250cec
How do I read this address from VTScada? I've tried all the Data Suffixes for Tag I/O Addressing but it didn't work. Below is the address "30001" in ModScan and its temperature reading. I've tried "30001/Float" but it didn't work. I also tried to do it through BuffOrder but I didn't understand correctly how to set it. ![66e47940293c9](serve/attachment&path=66e47940293c9) ![66e479407249f](serve/attachment&path=66e479407249f) Regarding the "Coils" they are working perfectly. ![66e4799250cec](serve/attachment&path=66e4799250cec)
edited Sep 25 '24 at 2:25 pm
I'm running into this exact problem. Will notify if I get it figured out. The best way I have found is to multiply the integer by 100 in PLC, address that tag in VTScada, and then divide the VTScada value by 100 (and set analog input to show decimal places). Does the same thing but annoying to have that many tags when there should be a simpler alternative.
if i am understanding correctly, try adjusting these settings.
and then it sounds like you need to adjust the scaling in your IO tag.
66fc5f9cc1743
if i am understanding correctly, try adjusting these settings. and then it sounds like you need to adjust the scaling in your IO tag. ![66fc5f9cc1743](serve/attachment&path=66fc5f9cc1743)
edited Oct 1 '24 at 9:48 pm
169
