Export to SQL
I am test driving the lite version. I am struggling to find clear "go here do this" document to connect this to a server SQL database. As anyone done this with lite?
Sounds like you are trying to connect to a SQL server, if this is correct, please you may want to start here: https://www.trihedral.com/help/Content/D_Tags/D_SQLDataQueryDriver.htm
For more information on this, and other more advanced topics such as using web services and ODBC, check out these documents:
VTScada Developer’s Guide
VTScada Programmer’s Guide
Sounds like you are trying to connect to a SQL server, if this is correct, please you may want to start here: https://www.trihedral.com/help/Content/D_Tags/D_SQLDataQueryDriver.htm For more information on this, and other more advanced topics such as using web services and ODBC, check out these documents: [VTScada Developer’s Guide](https://www.trihedral.com/wp-content/uploads/2016/09/VTScada11-2-DevelopersGuide.pdf) [VTScada Programmer’s Guide](https://www.trihedral.com/wp-content/uploads/2016/09/VTScada11-2-ProgrammersGuide.pdf)
Got this figured out, buried at page 748 of the developer's guide. SQL Data Logger Group. * Driver, New child, All tag types, SQL logger group. now configure the tabs to match your server. MAKE SURE you have imported the "Example" database table into your server.
Got this figured out, buried at page 748 of the developer's guide. SQL Data Logger Group. *** Driver, New child, All tag types, SQL logger group. now configure the tabs to match your server. MAKE SURE you have imported the "Example" database table into your server.
294
