We would like to clarify the following points related to VTScada historian storage and report export.
1) VTScada Historian Storage on NAS
We would like to confirm whether VTScada historical/tag data can be stored on a NAS (Network Attached Storage).
From VTScada documentation, we found that the Storage Location can be changed, but there is also a note stating:
“In general, do not specify a network location other than the hard drive of the Historian server(s).”
Based on this, could you please clarify:
Is it officially supported to store VTScada historian data on a NAS?
If NAS storage is supported, could you please clarify the recommended and supported connection method?
For example, should it be mounted as a local drive in Windows, or can it be used directly via a network shared folder path?
2) Recommended Approach for NAS Usage
We understand that NAS can be beneficial from a storage scalability point of view, especially for long-term capacity expansion and IT management.
If direct historian storage to NAS is not recommended, could you please advise the best practice?
For example:
Store historian data on local disk first, then back up/archive to NAS?
Or use NAS only for backup purposes instead of live historian storage?
3) Behavior After NAS Disconnection and Recovery
We would also like to confirm VTScada behavior if historian storage is configured to a NAS / network location and the NAS connection is temporarily lost and later restored.
Could you please confirm:
Will VTScada automatically recover and reconnect once the NAS is available again?
Or would any manual action be required, such as restarting the historian service, VTScada application, or server?
4) Report / Historical Data Export Interval
We would also like to confirm whether VTScada can generate reports based on a selected fixed interval.
For example, if a 5-minute interval is selected, we would expect the exported report to show one row per 5 minutes, such as:
Time Value
01:00:00 34
01:05:00 56
01:10:00 49
Whether VTScada supports this type of fixed interval data export/reporting
Whether the interval can be selected by the user (e.g. 1s, 5s, 10s, 1min, 5min, 1hr)
Where this setting can be configured
