I am trying to connect to Watlow F4T process controller. Its temperature setpoint is IEEE float, 2 registers. After testing, I found it is using BADC reversed IEEE. I chose Open Modbus TCP and Reverse IEEE Double Byte, but I don't get the correct value. I tried both relative and absolute addresses, but neither worked. Could someone help me with it? Or the LIGHT version doesn't support 2-register data?
Thank you
Thank you
