Can't view camera
I've created a camera tag and pointed it to my camera. the camera is configured for it's main feed to be mjpg and other feeds have been turned off. Besides my laptop with VTScada Lite for testing, there is nothing else on the network.
The camera widget remains grey. I have tried multiple ports: 80, 8080, 8000, 554 without success. Could someone provide direction on what I may be missing?
I have also used the webpage widget and can successfully get the login page for the camera, but when I login, it does not display video. Only the menu options and a black screen where the video should be.
Webview2 is installed. If I connect to the camera from outside VTScada, I can see the video without issue.
Thank you in advance. 😁
I've created a camera tag and pointed it to my camera. the camera is configured for it's main feed to be mjpg and other feeds have been turned off. Besides my laptop with VTScada Lite for testing, there is nothing else on the network. The camera widget remains grey. I have tried multiple ports: 80, 8080, 8000, 554 without success. Could someone provide direction on what I may be missing? I have also used the webpage widget and can successfully get the login page for the camera, but when I login, it does not display video. Only the menu options and a black screen where the video should be. Webview2 is installed. If I connect to the camera from outside VTScada, I can see the video without issue. Thank you in advance.
There are two initial items which come to mind. First, check if the camera's streaming server allows for viewing in an iframe. Second, check your VTScada application server list (and/or services page) to ensure that the camera service is being handled by a PC which can connect to the camera.
So definitely a camera issue. I've tried multiple viewers that use mjpeg and none of them would work. Ended up building a small app in C# that accpets rtsp h.264 and serves up multiple mjpeg feeds. That works well with the camera widget.
Is there any plan to support ONVIF for video feeds?
So definitely a camera issue. I've tried multiple viewers that use mjpeg and none of them would work. Ended up building a small app in C# that accpets rtsp h.264 and serves up multiple mjpeg feeds. That works well with the camera widget. Is there any plan to support ONVIF for video feeds?
45
