Master Tablets, Waystones & Remnants With U4GM’s POE 2 Guide
Path of Exile 2 Expedition has quickly become one of the most attractive endgame farming strategies for players who want consistent profits without a huge upfront investment. With the right Atlas configuration, tablets, Waystones, and Remnant management, experienced players can generate an impressive amount of POE2 Currency while spending relatively little on preparation. Some high-powered characters have reported earning around 50 to 60 Divines per hour, making Expedition one of the most efficient farming methods currently available.
One of the biggest advantages of Expedition is its low investment requirement. Unlike strategies that depend on expensive specialized materials, Expedition mainly requires a suitable map and a Logbook. This makes it accessible to many players who want to build their wealth without constantly spending large amounts of resources. In one farming session lasting approximately eight to nine hours, a player increased their Divine balance from 325 to 562. Even without counting valuable secondary drops, the raw Divine income alone exceeded 25 Divines per hour.
The total profit can become much higher when other rewards are included. Chaos Orbs, Perfect Exalted Orbs, Perfect Chaos, gems, Expedition rewards, and valuable equipment can all add significant value to each run. For a strong endgame character, reaching 50–60 Divines per hour is possible under favorable conditions. However, players should remember that these numbers represent high-end results rather than a guaranteed return for every build.
Expedition did receive an important change in the 0.5 update. Olroth's Saga was removed from its previous guaranteed setup and can now appear randomly on Grand Expedition maps. Because of this change, players should not expect the extremely high profits that were possible in the previous league. Nevertheless, Expedition remains very profitable because its basic investment requirements are still low.
For the tablet setup, three Eradicated Tablets are recommended. At the moment, Expedition Tablets do not work with Grand Expeditions, so Eradicated Tablets are the primary choice. Ideally, players should look for modifiers that increase Monster Effect or the number of Rare Monsters. Item Rarity is also useful but generally provides less value than the other options.
A one-mod tablet can be Divined in an attempt to gain a second modifier. Because the result is heavily affected by RNG, players should avoid overspending on this process. Expensive tablets are better reserved for extremely valuable five-, six-, or seven-mod maps. A practical spending limit is around 10 Divines per tablet. Players with weaker characters can instead use cheaper two-mod tablets, avoiding particularly dangerous Monster Effect combinations. Although the rewards may be lower, the reduced difficulty can make the strategy much safer and more consistent.
Waystones are another major part of the farming setup. Monster Effect should generally be the highest priority, followed by Monster Rarity and Item Rarity. Many players can use an Omen of Chaotic Quantity before corrupting their maps. Pack Size is usually not worth prioritizing unless it appears alongside an eight-mod map, where the large number of modifiers can make the map especially valuable.
The Atlas should focus primarily on Monster Effect if the character is strong enough to handle the increased difficulty. Players who are struggling can select Rarity instead. For the Expedition environment, Desert is generally the preferred option because of its stronger reward potential, while Forest provides an easier experience for less powerful characters.
Several Expedition passives are particularly valuable. Additional Remnant modifiers and explosives can improve each encounter, while additional Remnant counters provide more opportunities to build powerful combinations. The passive that increases quantity based on the number of Runic modifiers affecting monsters is also extremely important for maximizing rewards.
Master selection can further improve the strategy. Jato is recommended with Unexpected Missions, Eastern Knowledge, Partial Translations, and Keen Appraisal. Doryani can also work well, especially for weaker builds. His setup can provide additional revised Expedition encounters, helping players maintain their maps and reduce the risk of losing valuable Grand Expeditions.
Logbook rumors are less important than they once were because Logbooks are relatively inexpensive. Instead of spending too much time searching for a perfect rumor, players can simply run most of the Logbooks they encounter. Fallen Skies remains particularly valuable because it guarantees a Perfect Flux, while Sergeant Gear can lead to Uthred and potentially provide the quest item connected to Seeker's Call. Star Drinker is another option worth considering.
The most important part of Expedition farming is learning how to manage Runic Remnants. At the beginning of a Grand Expedition, focus on collecting powerful purple Remnants that can propagate their modifiers into later encounters. Toward the end, aim for as many seven-plus Remnants as possible, with eight or nine being ideal. A propagated modifier can continue affecting subsequent monster groups, creating enormous increases in quantity, rarity, and overall loot.
Opulent Remnants deserve special attention because they are exceptionally powerful. This golden Remnant improves the effectiveness of other modifiers, so players should generally prioritize it when it appears in an accessible location. Other valuable Remnants include Power, Death, Bond, Oath, Time, and Rebirth. Low-level Remnants with poor modifiers can usually be rerolled using Liquid Verisium, while guaranteed rewards worth one or more Divines should generally be preserved.
RNG still plays a major role in Expedition. A seemingly mediocre run can unexpectedly produce 10 raw Divines, while another Expedition may only provide three or four. Over a long farming session, however, an average of roughly eight to ten raw Divines per Expedition can still produce excellent returns. The key is learning how to recognize valuable Remnants, plan explosive routes, and avoid wasting resources on low-value combinations.
Overall, Expedition offers an excellent combination of low investment, strong rewards, and deep gameplay. It does require practice and a sufficiently powerful character because empowered monsters can become extremely dangerous. Some builds may need expensive equipment such as Headhunter before comfortably farming this content, while powerful setups such as Flameblast or Oil Grenade Gemling can perform well with less investment. If your character can consistently survive Grand Expeditions, mastering Remnant propagation and high-value modifiers can become one of the best ways to POE 2 Currency through your overall endgame progression strategy.
Path of Exile 2 Expedition has quickly become one of the most attractive endgame farming strategies for players who want consistent profits without a huge upfront investment. With the right Atlas configuration, tablets, Waystones, and Remnant management, experienced players can generate an impressive amount of [POE2 Currency](https://www.u4gm.com/path-of-exile-2/currency "POE2 Currency") while spending relatively little on preparation. Some high-powered characters have reported earning around 50 to 60 Divines per hour, making Expedition one of the most efficient farming methods currently available. One of the biggest advantages of Expedition is its low investment requirement. Unlike strategies that depend on expensive specialized materials, Expedition mainly requires a suitable map and a Logbook. This makes it accessible to many players who want to build their wealth without constantly spending large amounts of resources. In one farming session lasting approximately eight to nine hours, a player increased their Divine balance from 325 to 562. Even without counting valuable secondary drops, the raw Divine income alone exceeded 25 Divines per hour. The total profit can become much higher when other rewards are included. Chaos Orbs, Perfect Exalted Orbs, Perfect Chaos, gems, Expedition rewards, and valuable equipment can all add significant value to each run. For a strong endgame character, reaching 50–60 Divines per hour is possible under favorable conditions. However, players should remember that these numbers represent high-end results rather than a guaranteed return for every build. Expedition did receive an important change in the 0.5 update. Olroth's Saga was removed from its previous guaranteed setup and can now appear randomly on Grand Expedition maps. Because of this change, players should not expect the extremely high profits that were possible in the previous league. Nevertheless, Expedition remains very profitable because its basic investment requirements are still low. For the tablet setup, three Eradicated Tablets are recommended. At the moment, Expedition Tablets do not work with Grand Expeditions, so Eradicated Tablets are the primary choice. Ideally, players should look for modifiers that increase Monster Effect or the number of Rare Monsters. Item Rarity is also useful but generally provides less value than the other options. A one-mod tablet can be Divined in an attempt to gain a second modifier. Because the result is heavily affected by RNG, players should avoid overspending on this process. Expensive tablets are better reserved for extremely valuable five-, six-, or seven-mod maps. A practical spending limit is around 10 Divines per tablet. Players with weaker characters can instead use cheaper two-mod tablets, avoiding particularly dangerous Monster Effect combinations. Although the rewards may be lower, the reduced difficulty can make the strategy much safer and more consistent. Waystones are another major part of the farming setup. Monster Effect should generally be the highest priority, followed by Monster Rarity and Item Rarity. Many players can use an Omen of Chaotic Quantity before corrupting their maps. Pack Size is usually not worth prioritizing unless it appears alongside an eight-mod map, where the large number of modifiers can make the map especially valuable. The Atlas should focus primarily on Monster Effect if the character is strong enough to handle the increased difficulty. Players who are struggling can select Rarity instead. For the Expedition environment, Desert is generally the preferred option because of its stronger reward potential, while Forest provides an easier experience for less powerful characters. Several Expedition passives are particularly valuable. Additional Remnant modifiers and explosives can improve each encounter, while additional Remnant counters provide more opportunities to build powerful combinations. The passive that increases quantity based on the number of Runic modifiers affecting monsters is also extremely important for maximizing rewards. Master selection can further improve the strategy. Jato is recommended with Unexpected Missions, Eastern Knowledge, Partial Translations, and Keen Appraisal. Doryani can also work well, especially for weaker builds. His setup can provide additional revised Expedition encounters, helping players maintain their maps and reduce the risk of losing valuable Grand Expeditions. Logbook rumors are less important than they once were because Logbooks are relatively inexpensive. Instead of spending too much time searching for a perfect rumor, players can simply run most of the Logbooks they encounter. Fallen Skies remains particularly valuable because it guarantees a Perfect Flux, while Sergeant Gear can lead to Uthred and potentially provide the quest item connected to Seeker's Call. Star Drinker is another option worth considering. The most important part of Expedition farming is learning how to manage Runic Remnants. At the beginning of a Grand Expedition, focus on collecting powerful purple Remnants that can propagate their modifiers into later encounters. Toward the end, aim for as many seven-plus Remnants as possible, with eight or nine being ideal. A propagated modifier can continue affecting subsequent monster groups, creating enormous increases in quantity, rarity, and overall loot. Opulent Remnants deserve special attention because they are exceptionally powerful. This golden Remnant improves the effectiveness of other modifiers, so players should generally prioritize it when it appears in an accessible location. Other valuable Remnants include Power, Death, Bond, Oath, Time, and Rebirth. Low-level Remnants with poor modifiers can usually be rerolled using Liquid Verisium, while guaranteed rewards worth one or more Divines should generally be preserved. RNG still plays a major role in Expedition. A seemingly mediocre run can unexpectedly produce 10 raw Divines, while another Expedition may only provide three or four. Over a long farming session, however, an average of roughly eight to ten raw Divines per Expedition can still produce excellent returns. The key is learning how to recognize valuable Remnants, plan explosive routes, and avoid wasting resources on low-value combinations. Overall, Expedition offers an excellent combination of low investment, strong rewards, and deep gameplay. It does require practice and a sufficiently powerful character because empowered monsters can become extremely dangerous. Some builds may need expensive equipment such as Headhunter before comfortably farming this content, while powerful setups such as Flameblast or Oil Grenade Gemling can perform well with less investment. If your character can consistently survive Grand Expeditions, mastering Remnant propagation and high-value modifiers can become one of the best ways to [POE 2 Currency](https://www.u4gm.com/path-of-exile-2/currency "POE 2 Currency") through your overall endgame progression strategy.
