How to Juice Grand Expeditions in POE2 — U4GM Guide
Expedition has established itself as one of the most attractive low-investment farming methods in Path of Exile 2. With only a map and a Logbook required to get started, players can potentially generate large amounts of POE2 Currency while also collecting Chaos Orbs, Divine Orbs, gems, Perfect Exalts, and valuable Expedition rewards. However, the impressive results shown by experienced farmers do not come entirely from luck. Successful Expedition farming requires careful Tablet preparation, strong Atlas choices, efficient Rune selection, and an understanding of how Rune propagation works.
The strategy became slightly different after the changes introduced in patch 0.5.5. Olroth's Saga was removed from normal Event League spawning and can now appear randomly on Grand Expedition maps. This reduced the extreme profit potential that some players experienced during the previous league, but Expedition remains highly profitable because its basic investment is still relatively low. The source describes an eight-to-nine-hour farming session that increased its Divine total from 325 to 562. Raw Divine drops alone averaged more than 25 per hour during that session, while additional loot from Chaos, Perfect Exalts, gems, and Expedition rewards pushed the potential return considerably higher. These numbers represent personal results rather than guaranteed income, since Expedition rewards are strongly affected by RNG and character power.
Choosing the Right Tablets
Tablet selection is one of the most important parts of a juiced Expedition setup. The recommended approach is to use three Eradicated Tablets for high-value Grand Expeditions. According to the source, Excision Tablets currently do not work with Grand Expeditions, so they should not be part of this setup.
The ideal modifiers are Monster Effect and increased Rare Monsters. Item Rarity can also be useful, but it is generally less desirable than the other options. Three Tablets are more expensive, so they make the most sense when used on exceptional maps with five, six, or seven modifiers. For players who are still learning the strategy, two-modifier Tablets can provide a cheaper alternative. Combining increased Rare Monsters, Monster Effect, and Monster Rarity can reduce the difficulty while still producing respectable rewards.
Optimizing Waystones and the Atlas
Waystones should focus on Monster Effect first, followed by Monster Rarity and Item Rarity. The source recommends using an Omen of Chaotic Quantity and avoiding Pack Size on ordinary maps. An eight-modifier map with Pack Size can still be worth keeping because the large number of modifiers may justify the additional risk.
For the Atlas, Monster Effect is the standard choice when the character can handle the increased difficulty. Players struggling with survivability can instead use Rarity to make the content easier. Desert Expedition layouts are preferred for stronger rewards, while Forest can be selected by players who want a more manageable experience.
Master selection also matters. The recommended setup uses Jatko with Unexpected Missions, Eastern Knowledge, Partial Translations, and Keen Appraisal. Doriani is another option, particularly for weaker characters. A suitable Doriani setup can provide additional revised Expedition encounters and make difficult content easier to manage. Regardless of the exact setup, surviving Grand Expeditions is essential because repeatedly losing maps can quickly reduce the efficiency of the entire strategy.
How Rune Propagation Works
The central mechanic behind high-value Expedition runs is Rune propagation. At the beginning of a Grand Expedition, players should focus on collecting strong purple Runes rather than immediately chasing the highest Rune count. The objective is to use those early Runes to build toward powerful seven-plus Rune combinations near the end.
A highlighted Rune can propagate into subsequent Remnants and monster groups. This means an excellent Rune obtained early can continue affecting multiple encounters throughout the rest of the Expedition. The ideal scenario is to carry numerous strong Runes into a final seven-, eight-, or nine-Rune combination. More Rune effects mean stronger monsters and substantially more opportunities for valuable loot.
The Opulent Rune deserves special attention because it is the only golden Rune mentioned in the strategy. Its effect can greatly improve the value of other Runes, making it worth prioritizing when the map layout allows it. Other useful choices include Power, Death, Bond, and Oath, while Time and Rebirth can also provide solid results.
At the beginning of a map, five-or-fewer Rune combinations without useful purple effects can usually be rerolled. Liquid Verisium allows players to reroll Rune options, and the source describes it as effectively self-sustaining during regular Expedition farming. Guaranteed rewards should be treated differently: if a Remnant offers a Divine or another item worth roughly a Divine or more, keeping that reward can be more valuable than chasing another Rune combination.
Managing Variance and Profit
Not every Expedition will produce spectacular results. Some runs may generate only three or four raw Divines, while particularly fortunate maps can produce 20 or more. The source estimates a long-term average of roughly eight to ten Divines per Expedition, but actual results vary significantly. Map layout, Rune locations, explosive placement, modifiers, and random drops all influence the final result.
This makes practice extremely important. Players should learn which Runes are worth prioritizing, when to reroll, how to connect Rune chains, and when it is better to skip an encounter. Explosives can be used early to save time or saved until the end for more controlled execution. Map objectives can also provide useful rewards, but they should generally not take priority over strong Rune combinations unless the player has spare explosives.
Expedition is also demanding combat content. A strong character is necessary to handle the large number of Rare Monsters created by heavily juiced maps. Some builds may require substantial investment before they can farm this strategy comfortably, while particularly powerful builds can enter earlier. Players should therefore balance loot potential against survivability rather than blindly maximizing every modifier.
Overall, Expedition rewards players who combine efficient preparation with careful decision-making. The most important lesson is to build strong Rune chains early and finish with high-value seven-plus Rune combinations, ideally supported by powerful purple effects and Opulent. With enough practice, even average-looking maps can produce worthwhile results, while exceptional runs can generate enormous amounts of loot. Players who need to strengthen their characters before tackling heavily juiced Grand Expeditions can farm their resources naturally or buy POE 2 Mirror of Kalandra to accelerate their progression and prepare for this demanding but rewarding strategy.
Expedition has established itself as one of the most attractive low-investment farming methods in Path of Exile 2. With only a map and a Logbook required to get started, players can potentially generate large amounts of [POE2 Currency](https://www.u4gm.com/path-of-exile-2/currency "POE2 Currency") while also collecting Chaos Orbs, Divine Orbs, gems, Perfect Exalts, and valuable Expedition rewards. However, the impressive results shown by experienced farmers do not come entirely from luck. Successful Expedition farming requires careful Tablet preparation, strong Atlas choices, efficient Rune selection, and an understanding of how Rune propagation works. The strategy became slightly different after the changes introduced in patch 0.5.5. Olroth's Saga was removed from normal Event League spawning and can now appear randomly on Grand Expedition maps. This reduced the extreme profit potential that some players experienced during the previous league, but Expedition remains highly profitable because its basic investment is still relatively low. The source describes an eight-to-nine-hour farming session that increased its Divine total from 325 to 562. Raw Divine drops alone averaged more than 25 per hour during that session, while additional loot from Chaos, Perfect Exalts, gems, and Expedition rewards pushed the potential return considerably higher. These numbers represent personal results rather than guaranteed income, since Expedition rewards are strongly affected by RNG and character power. Choosing the Right Tablets Tablet selection is one of the most important parts of a juiced Expedition setup. The recommended approach is to use three Eradicated Tablets for high-value Grand Expeditions. According to the source, Excision Tablets currently do not work with Grand Expeditions, so they should not be part of this setup. The ideal modifiers are Monster Effect and increased Rare Monsters. Item Rarity can also be useful, but it is generally less desirable than the other options. Three Tablets are more expensive, so they make the most sense when used on exceptional maps with five, six, or seven modifiers. For players who are still learning the strategy, two-modifier Tablets can provide a cheaper alternative. Combining increased Rare Monsters, Monster Effect, and Monster Rarity can reduce the difficulty while still producing respectable rewards. Optimizing Waystones and the Atlas Waystones should focus on Monster Effect first, followed by Monster Rarity and Item Rarity. The source recommends using an Omen of Chaotic Quantity and avoiding Pack Size on ordinary maps. An eight-modifier map with Pack Size can still be worth keeping because the large number of modifiers may justify the additional risk. For the Atlas, Monster Effect is the standard choice when the character can handle the increased difficulty. Players struggling with survivability can instead use Rarity to make the content easier. Desert Expedition layouts are preferred for stronger rewards, while Forest can be selected by players who want a more manageable experience. Master selection also matters. The recommended setup uses Jatko with Unexpected Missions, Eastern Knowledge, Partial Translations, and Keen Appraisal. Doriani is another option, particularly for weaker characters. A suitable Doriani setup can provide additional revised Expedition encounters and make difficult content easier to manage. Regardless of the exact setup, surviving Grand Expeditions is essential because repeatedly losing maps can quickly reduce the efficiency of the entire strategy. How Rune Propagation Works The central mechanic behind high-value Expedition runs is Rune propagation. At the beginning of a Grand Expedition, players should focus on collecting strong purple Runes rather than immediately chasing the highest Rune count. The objective is to use those early Runes to build toward powerful seven-plus Rune combinations near the end. A highlighted Rune can propagate into subsequent Remnants and monster groups. This means an excellent Rune obtained early can continue affecting multiple encounters throughout the rest of the Expedition. The ideal scenario is to carry numerous strong Runes into a final seven-, eight-, or nine-Rune combination. More Rune effects mean stronger monsters and substantially more opportunities for valuable loot. The Opulent Rune deserves special attention because it is the only golden Rune mentioned in the strategy. Its effect can greatly improve the value of other Runes, making it worth prioritizing when the map layout allows it. Other useful choices include Power, Death, Bond, and Oath, while Time and Rebirth can also provide solid results. At the beginning of a map, five-or-fewer Rune combinations without useful purple effects can usually be rerolled. Liquid Verisium allows players to reroll Rune options, and the source describes it as effectively self-sustaining during regular Expedition farming. Guaranteed rewards should be treated differently: if a Remnant offers a Divine or another item worth roughly a Divine or more, keeping that reward can be more valuable than chasing another Rune combination. Managing Variance and Profit Not every Expedition will produce spectacular results. Some runs may generate only three or four raw Divines, while particularly fortunate maps can produce 20 or more. The source estimates a long-term average of roughly eight to ten Divines per Expedition, but actual results vary significantly. Map layout, Rune locations, explosive placement, modifiers, and random drops all influence the final result. This makes practice extremely important. Players should learn which Runes are worth prioritizing, when to reroll, how to connect Rune chains, and when it is better to skip an encounter. Explosives can be used early to save time or saved until the end for more controlled execution. Map objectives can also provide useful rewards, but they should generally not take priority over strong Rune combinations unless the player has spare explosives. Expedition is also demanding combat content. A strong character is necessary to handle the large number of Rare Monsters created by heavily juiced maps. Some builds may require substantial investment before they can farm this strategy comfortably, while particularly powerful builds can enter earlier. Players should therefore balance loot potential against survivability rather than blindly maximizing every modifier. Overall, Expedition rewards players who combine efficient preparation with careful decision-making. The most important lesson is to build strong Rune chains early and finish with high-value seven-plus Rune combinations, ideally supported by powerful purple effects and Opulent. With enough practice, even average-looking maps can produce worthwhile results, while exceptional runs can generate enormous amounts of loot. Players who need to strengthen their characters before tackling heavily juiced Grand Expeditions can farm their resources naturally or [buy POE 2 Mirror of Kalandra](https://www.u4gm.com/path-of-exile-2/currency "buy POE 2 Mirror of Kalandra") to accelerate their progression and prepare for this demanding but rewarding strategy.
