Building an elite tight end in College Football 27 Dynasty Mode is more complicated than simply recruiting a fast receiver and moving him to a new position. After three months of testing different archetypes and position conversions, one important lesson stands out: finding the right balance between receiving ability and blocking skills requires a smarter approach. For players managing their roster and planning their in-game resources, CFB 27 Coins may be part of the wider Dynasty experience, but choosing the right player archetype is what makes the biggest difference on the field.
The Problem with Converted Wide Receivers
A converted wide receiver can look like the perfect tight end at first. Players such as Keenan Jackson offer impressive speed, acceleration, and route running. With ratings above 90 in some athletic categories, they can create mismatches against linebackers and become dangerous receiving targets.
However, position conversion comes with an important drawback. When a wide receiver moves to tight end, the game typically assigns him the Vertical Threat archetype. This creates problems when developing his blocking ability. Even if you spend skill points upgrading run blocking, you may only improve the standard run block rating. Other important attributes, including run block power and run block finesse, can remain extremely low.
Traditional blocking tight ends have the opposite weakness. Ryan Woler, for example, offers much better blocking than Keenan Jackson, but his speed, route running, and catching ability make him a limited receiving option. Neither player provides everything needed for a complete tight end.
Why the Pure Blocker Archetype Stands Out
There are four major areas to consider when evaluating a tight end: athleticism, route running, hands, and blocking. Blocking itself includes regular run blocking, run block power, run block finesse, and impact blocking.
These attributes determine whether a tight end can protect the quarterback, create running lanes, reach linebackers downfield, and contribute as a receiver.
Among the available tight end archetypes, Pure Blocker has one major advantage. All four important blocking attributes are connected to a single upgrade group. Testing by Dynasty-focused creators has also shown that upgrading this group can improve hidden blocking ratings, even when every attribute is not displayed directly in the upgrade menu.
This makes Pure Blocker the most reliable option for developing a genuinely effective run blocker. However, there is a significant disadvantage: speed.
Pure Blocker tight ends often begin with around 72 speed. Although route running and catching can be improved, increasing speed to the level of a converted wide receiver is extremely expensive. Spending large amounts of skill points just to close that athletic gap is rarely an efficient development strategy.
Why Position Conversions Usually Fail
One possible solution is converting fast players from other positions into Pure Blocker tight ends. In theory, a player with 90 speed and acceleration could become an outstanding all-around option if he also gained access to the Pure Blocker upgrade group.
Unfortunately, testing different positions reveals two major obstacles.
The first is skill caps. North-South Blocking running backs, for example, can offer good speed and physical ability, but their route-running and catching caps are often too low. Even after conversion, they may struggle to reach 75 in either receiving category.
The second problem is archetype classification. When EA converts a player to a new position, it calculates which archetype best matches his weighted ratings. Speed, acceleration, and catching are heavily valued by the Vertical Threat archetype. As a result, most converted wide receivers automatically become Vertical Threats instead of Pure Blockers.
Experiments with athlete linebackers and players temporarily developed at offensive line positions produced only limited success. Even when a player became a Pure Blocker, skill caps frequently prevented him from reaching the desired receiving standards.
Finding the Best Overall Balance
To compare the options fairly, four categories can be weighted equally: athleticism, route running, hands, and blocking. Using average ratings from three-star recruits and assuming each archetype receives 100 skill points creates a useful model for evaluating long-term development.
The results favor Pure Blockers as the most balanced option overall. Gritty Possession wide receiver conversions can perform very well in speed, route running, and catching, but their blocking remains a major weakness. In the comparison, their weighted blocking average reaches only 14.3, while Pure Blockers reach 20.7.
That difference matters because improving a weak blocking archetype is much harder than developing the receiving abilities of a Pure Blocker. A converted receiver may become an excellent pass-catching tight end, but turning him into a dependable run blocker is a much bigger challenge.
The Best Dynasty Roster Strategy
The most practical solution is not to expect one tight end to handle every responsibility. Instead, build a roster with two complementary players.
First, scout Pure Blocker tight ends and prioritize the fastest recruits available. An 82-speed Pure Blocker may not match the athleticism of an 88-speed receiver conversion, but he offers a much stronger foundation for blocking development. Upgrade his blocking first, then invest in route running and catching to make him more versatile.
Second, keep a converted wide receiver as a receiving specialist. His speed and route-running ability can create separation, stretch the defense, and provide another reliable target in passing situations.
This two-player approach gives your offense more flexibility. You can use the Pure Blocker in running formations and situations that demand physical protection, while the converted receiver becomes a matchup weapon when you need to attack through the air.
The biggest lesson is that no single archetype can reach elite levels in every category without major compromises. Recruiting the fastest available Pure Blocker and pairing him with a talented receiving specialist is a much more realistic way to build a dangerous tight end room in Dynasty Mode. With the right development priorities and roster planning, CUT Coins can support your broader in-game goals while your two-specialist strategy gives the offense the versatility it needs.
Building an elite tight end in College Football 27 Dynasty Mode is more complicated than simply recruiting a fast receiver and moving him to a new position. After three months of testing different archetypes and position conversions, one important lesson stands out: finding the right balance between receiving ability and blocking skills requires a smarter approach. For players managing their roster and planning their in-game resources, [CFB 27 Coins](https://www.u4gm.com/college-football-27/coins "CFB 27 Coins") may be part of the wider Dynasty experience, but choosing the right player archetype is what makes the biggest difference on the field.
The biggest lesson is that no single archetype can reach elite levels in every category without major compromises. Recruiting the fastest available Pure Blocker and pairing him with a talented receiving specialist is a much more realistic way to build a dangerous tight end room in Dynasty Mode. With the right development priorities and roster planning, [CUT Coins](https://www.u4gm.com/college-football-27/coins "CUT Coins") can support your broader in-game goals while your two-specialist strategy gives the offense the versatility it needs.
