Plotxy
Hey all, I need to use the plotxy function to display a xy graph. Has anyone use this before?
My main question would be. How to generate the X and Y arrays. Would you use the GetTagHistory function to generate these arrays?
Hey all, I need to use the plotxy function to display a xy graph. Has anyone use this before? My main question would be. How to generate the X and Y arrays. Would you use the GetTagHistory function to generate these arrays?
What are you trying to accomplish here?
Is it something like:
6109509fd7f1f
What are you trying to accomplish here? Is it something like: ![6109509fd7f1f](serve/attachment&path=6109509fd7f1f)
Here is an example that is apart of the Pump Off Controller Dynacard.
Basically plot two variables against each other.
For example x-axis = Pressure, y-axis = Temperature.
6109927c9e246
Here is an example that is apart of the Pump Off Controller Dynacard. Basically plot two variables against each other. For example x-axis = Pressure, y-axis = Temperature. ![6109927c9e246](serve/attachment&path=6109927c9e246)
148
