Leading zeroes in numerical conversion to string
I am trying to create a text port that allows the user to enter a lift station number and then click to open the detail page for that station. In order to make everything work smoothly I need my lift station number to resolve to a three digit string. Is there a function that will force leading zeroes in an integer to string conversion? The Format function seems to operate in exact reverse of what I need (oddly).
Thanks
I am trying to create a text port that allows the user to enter a lift station number and then click to open the detail page for that station. In order to make everything work smoothly I need my lift station number to resolve to a three digit string. Is there a function that will force leading zeroes in an integer to string conversion? The Format function seems to operate in exact reverse of what I need (oddly). Thanks
If you need it as an expression then this should work, where "n" is the number:
Concat(MakeBuff(2-Int(Log(n)), 0x30) , Format(0,0,n))
If you need it as an expression then this should work, where "n" is the number: Concat(MakeBuff(2-Int(Log(n)), 0x30) , Format(0,0,n))
Lawrence MacNeil
Trihedral Engineering Limited
edited Jan 16 '23 at 6:34 pm
109
