SNMP Application
I configured an application with SNMP, but when I finished I noticed that the application does not receive a response for Gets. I followed the configuration in the VTScada Help
63769000bd7f7
I configured an application with SNMP, but when I finished I noticed that the application does not receive a response for Gets. I followed the configuration in the VTScada Help ![63769000bd7f7](serve/attachment&path=63769000bd7f7)
Hey Othmania, we spoke earlier in the day on the Website Chat. Thanks for posting this.
Error code 21 suggests that there is no connected port. Also, the lack of a value on your port tag suggests this may be an accurate code.
In your tag structure, it appears that the driver is a child of the port, so the default [*Driver] is something I would expect to work. You can try directly connecting the port tag property in the SNMP_Drive tag to your TCP/IP Port tag.
This is just a guess, as I am no expert with SNMP.
Hey Othmania, we spoke earlier in the day on the Website Chat. Thanks for posting this. Error code 21 suggests that there is no connected port. Also, the lack of a value on your port tag suggests this may be an accurate code. In your tag structure, it appears that the driver is a child of the port, so the default [*Driver] is something I would expect to work. You can try directly connecting the port tag property in the SNMP_Drive tag to your TCP/IP Port tag. This is just a guess, as I am no expert with SNMP.
