Pulling Info from two different PLC's
I am trying to use VTScadaLight to pull info from two different CPU's. They both have two different IP addresses and I was wondering if VTScadaLight can pull info from the two CPUs at the same time?
Hello, I am trying to use VTScadaLight to pull info from two different CPU's. They both have two different IP addresses and I was wondering if VTScadaLight can pull info from the two CPUs at the same time?
Yes, it is quite common for SCADA to communicated with multiple devices. Just set up the approprate port tags, driver tags, and IO tags for each.
38
