Colourising indicators doesn't seem to be working
I've been using VTScada for a while now but one thing I cannot get to work is colourising Indicators.
All I want to do is have an indicator that in OFF state from a digital status tag is one colour and that in ON state from the same tag is green or yellow or red.
When I try to colourise and link the tag to any of the indicators all I get is grey when OFF and white when ON.
I'm clearly not understanding something simple here, can anyone help?
Thanks
Scott
I've been using VTScada for a while now but one thing I cannot get to work is colourising Indicators. All I want to do is have an indicator that in OFF state from a digital status tag is one colour and that in ON state from the same tag is green or yellow or red. When I try to colourise and link the tag to any of the indicators all I get is grey when OFF and white when ON. I'm clearly not understanding something simple here, can anyone help? Thanks Scott
Sounds like the widget is looking at the sytle tag that is linked as default - see help files below:
If it is the below type - the style tag controls the colour.
https://www.vtscada.com/help/Content/D_Widgets/Dev_IndicatorLightWidget.htm
Check the section: "Style Settings properties Digitals tab" at:
https://www.vtscada.com/help/Content/D_Tags/Dev_StyleSettings.htm
You can create a new style tag for the different configurations that you may need.
Did that help...?
Sounds like the widget is looking at the sytle tag that is linked as default - see help files below: If it is the below type - the style tag controls the colour. https://www.vtscada.com/help/Content/D_Widgets/Dev_IndicatorLightWidget.htm Check the section: "Style Settings properties Digitals tab" at: https://www.vtscada.com/help/Content/D_Tags/Dev_StyleSettings.htm You can create a new style tag for the different configurations that you may need. Did that help...?
210
