Activation and the SI Developer's Key
Question - How does the new Activation affect my SI developer key? I currently have a few different versions of VTScada installed on my computer for use in development with different customers. I assume this won’t affect versions before 11.2.25, but what about going forward? Will I be able to install multiple versions of VTScada after 11.2.25? I like to work on their applications in the version they have installed, so I don’t accidentally rely on a new feature in my programming that isn’t available in their installed version.
Answer - The activation applies to the computer, so once a computer has received the activation code, it will not ever need to be activated again no matter which VTScada versions you run on that machine.
Question - How does the new Activation affect my SI developer key? I currently have a few different versions of VTScada installed on my computer for use in development with different customers. I assume this won’t affect versions before 11.2.25, but what about going forward? Will I be able to install multiple versions of VTScada after 11.2.25? I like to work on their applications in the version they have installed, so I don’t accidentally rely on a new feature in my programming that isn’t available in their installed version. Answer - The activation applies to the computer, so once a computer has received the activation code, it will not ever need to be activated again no matter which VTScada versions you run on that machine.
144
