How to send a SOAP Webservice request from VTScada application to third-part webservice
I have a webservice and on my VTScada application, I want to get data from webservice. So how can I send a request to webservice via SOAP ?
edited Nov 8 '22 at 1:47 pm
You will need to use the HTTPSend() function to send the SOAP message, your application will require custom scripting to create the message and decode the response(s). The documentation for the HTTPSend() function can be found here:
https://www.vtscada.com/help/Content/Pro_Functions/HTTPSend.htm
You will need to use the HTTPSend() function to send the SOAP message, your application will require custom scripting to create the message and decode the response(s). The documentation for the HTTPSend() function can be found here: https://www.vtscada.com/help/Content/Pro_Functions/HTTPSend.htm
Lawrence MacNeil
Trihedral Engineering Limited
74
