Separate First Page for 2 different users in same project/realm (remote client)
Hello, experts.
In the project, there is a requirement to separate users. That is, different users will enter a different first page when logging in. It is intended to create some isolation between users. That is, user 1 will enter a general map with the option of switching between the stations, and user 2 will only enter a central screen without the possibility of switching. Is this possible?
VTS 11.0.07
Thank you in advance
Hello, experts. In the project, there is a requirement to separate users. That is, different users will enter a different first page when logging in. It is intended to create some isolation between users. That is, user 1 will enter a general map with the option of switching between the stations, and user 2 will only enter a central screen without the possibility of switching. Is this possible? VTS 11.0.07 Thank you in advance
You could probably do this with some Security Realms and add some security levels to the pages.
https://www.vtscada.com/help/Content/D_Customize/D_UserGroups.htm?Highlight=realm
They may be called "User Groups" in the older V11 version. It's been awhile since I've worked on that one.
You could probably do this with some Security Realms and add some security levels to the pages. https://www.vtscada.com/help/Content/D_Customize/D_UserGroups.htm?Highlight=realm They may be called "User Groups" in the older V11 version. It's been awhile since I've worked on that one.
29
