how to remove the empty gap when display multi window in one display screen
I want to get two display windows at the same time in one display screen. After set DispMgrHoriz =2 and DispMgrVert=1, I can get two windows, but there are some gaps as the following screen capture.
6372ebfa986b1
How can I remove the gaps while retaining the white title bar? Thanks.
I want to get two display windows at the same time in one display screen. After set DispMgrHoriz =2 and DispMgrVert=1, I can get two windows, but there are some gaps as the following screen capture. ![6372ebfa986b1](serve/attachment&path=6372ebfa986b1) How can I remove the gaps while retaining the white title bar? Thanks.
edited Nov 15 '22 at 1:41 am
If the windows do not have any memory after restarting the app, have you tested setting the windows to fixed initial sizes using the application settings?
hi Dave, whould you like to take the time to help test this?would you like to give a demo setting? thanks.
31
