SQL Query Driver
Can I get some help in defining a SQL Driver template for pulling values from another VTScada system?
ODBC driver is installed, user account with remote data permissions created, realm created, DSN defined, connection verified.
There is no option in the database type list for VTScada. What should be chosen here?
I made a probably incorrect assumption that a query should follow the format described in the SQL query documentation here
SELECT '^A' , Timestamp FROM History ORDER BY Timestamp DESC LIMIT 1
Where address of the I/O tag attached to the SQL Query Driver is
RemoteContext\Sub Context\Interesting Part:Value
This, of course, is not working. I just want the latest value for tags. Some help with this "Instantly Intuitive"™ task would be appreciated.
Can I get some help in defining a SQL Driver template for pulling values from another VTScada system? ODBC driver is installed, user account with remote data permissions created, realm created, DSN defined, connection verified. There is no option in the database type list for VTScada. What should be chosen here? I made a probably incorrect assumption that a query should follow the format described in the SQL query documentation [here](https://www.vtscada.com/help/Content/D_LogAndReport/Dev_SQLQueryExamples.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____3) ```` SELECT '^A' , Timestamp FROM History ORDER BY Timestamp DESC LIMIT 1 ```` Where address of the I/O tag attached to the SQL Query Driver is ```` RemoteContext\Sub Context\Interesting Part:Value ```` This, of course, is not working. I just want the latest value for tags. Some help with this "Instantly Intuitive"™ task would be appreciated.
I've included some references below, but to get the current value, along with other tag properties, you can skip the history table, which is looking for a date range and use something similar to:
https://myServer/myRealm/REST/SQLQuery?query=SELECT%20Name,%20ShortName,%20Description,%20Area,%20Value%20FROM%20Parms_AllTypes
Where %20 is simply used to show a space if you were to try this in a web browser (don't since myServer/myRealm does not exist smile )
Also, in the query above, you can use tag types, areas, or reference a SQL View Tag to limit your results to those you are looking for.
The ODBC driver is for a client machine and receives ODBC but queries VTScada using the REST Interface.
SQL View Tag: https://www.vtscada.com/help/Content/D_Tags/D_SQLView.htm
REST Interface: https://www.vtscada.com/help/Content/D_LogAndReport/D_RESTQueries.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____4
SQL Queries Examples: https://www.vtscada.com/help/Content/D_LogAndReport/Dev_SQLQueryExamples.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____3
I've included some references below, but to get the current value, along with other tag properties, you can skip the history table, which is looking for a date range and use something similar to: https://myServer/myRealm/REST/SQLQuery?query=SELECT%20Name,%20ShortName,%20Description,%20Area,%20Value%20FROM%20Parms_AllTypes Where %20 is simply used to show a space if you were to try this in a web browser (don't since myServer/myRealm does not exist :) ) Also, in the query above, you can use tag types, areas, or reference a SQL View Tag to limit your results to those you are looking for. The ODBC driver is for a client machine and receives ODBC but queries VTScada using the REST Interface. SQL View Tag: https://www.vtscada.com/help/Content/D_Tags/D_SQLView.htm REST Interface: https://www.vtscada.com/help/Content/D_LogAndReport/D_RESTQueries.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____4 SQL Queries Examples: https://www.vtscada.com/help/Content/D_LogAndReport/Dev_SQLQueryExamples.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____3
Dave,
Thanks for the response, but I've read all of your links previously. I cannot grant access to tag parameters to the ODBC account to access the Parms_AllTypes table.
Is this not correct?:
https://forum.trihedral.com/index.php?u=/topic/636/use-json-xml-driver-in-vtscada-a-to-read-a-tag-from-vtscada-b/post-1894#post-1894
The query described in my initial post works perfectly fine when using a third party browser. When adapted to a template in the SQL Data Query Driver returns a value of "8".
Since you didn't reference the SQL Query Driver at all, I'm going assume that Graham is incorrect and the SQL Query Driver Tag is not intended to share data between VTScada installations, and cannot be configured to do so.
Thanks for your time.
Dave, Thanks for the response, but I've read all of your links previously. I cannot grant access to tag parameters to the ODBC account to access the Parms_AllTypes table. Is this not correct?: https://forum.trihedral.com/index.php?u=/topic/636/use-json-xml-driver-in-vtscada-a-to-read-a-tag-from-vtscada-b/post-1894#post-1894 The query described in my initial post works perfectly fine when using a third party browser. When adapted to a template in the SQL Data Query Driver returns a value of "8". Since you didn't reference the SQL Query Driver at all, I'm going assume that Graham is incorrect and the SQL Query Driver Tag is not intended to share data between VTScada installations, and cannot be configured to do so. Thanks for your time.
262
