Recipe stored in dictionary get lost after application restart
I have created a script to store recipe in a Network Value variable. This variable is declared in Approot.src under NETWORKVALUE. code works fine till application is running but the problem is when I restart the application I can not find stored recipe. Is there anything I am missing which results into this problem ?
edited Jan 26 '23 at 4:45 am
A couple of questions for you:
1) What is the data type of the variable that you're trying to store as a Network Value?
2) Can we get a copy of your source code to review?
3) Have you tried using the Recipe tags in VTScada? See https://www.vtscada.com/help/Content/D_Tags/D_RecipeTags.htm?tocpath=Reference%7CTag%20Reference%7CRecipe%20and%20Batch%20Processing%20Tags%7C_____0
A couple of questions for you: 1) What is the data type of the variable that you're trying to store as a Network Value? 2) Can we get a copy of your source code to review? 3) Have you tried using the Recipe tags in VTScada? See https://www.vtscada.com/help/Content/D_Tags/D_RecipeTags.htm?tocpath=Reference%7CTag%20Reference%7CRecipe%20and%20Batch%20Processing%20Tags%7C_____0
Lawrence MacNeil
Trihedral Engineering Limited
30
