Alarm Priority and Disable
I'd like to be able to allow the operator to disable alarms and adjust alarm priorities from the HMI itself without having to navigate the settings. Are there widgets I can use to accommodate this?
No but it's possible to build them with expressions and memory tags.
Thanks for the response. I'm not familiar with memory tags. I'll do some research on them.
I've been experimenting with the same thing. The expressions work pretty well and I've been using them either in the start condition of a tag that I don't want to alarm, or in the alarm disable field of that tag (if I still want to read the values in the tag, but don't want it to alarm)
Speaking of the alarm disable property, how were you able to toggle that with an expression? I can't seem to assign it a value in an expression.
Update. I learned you can pass a tag with an expression to the alarm priority.
You right click the check box like you do with other parameter expression fields. Or if you are doing the bulk import excel spreadsheet, I think the alarm disable field is named something like alarminhibit, with different names depending if its the hi/lo alarm, etc.
64
6
