Negative values as 0
Is there a tag setting to interpret negative variable values as 0 ?
Hello, Is there a tag setting to interpret negative variable values as 0 ?
Yes, you can define min and max values in the tag scaling.
Hi Dave,
The tag is scalled with 0 min value.
64992a822f963
Still i get the negative value.
64992a81db4d4
Hi Dave, The tag is scalled with 0 min value. ![64992a822f963](serve/attachment&path=64992a822f963) Still i get the negative value. ![64992a81db4d4](serve/attachment&path=64992a81db4d4)
edited Jun 26 '23 at 7:07 am
Sorry, the display range is for certain widgets but does not affect the tags read value. The scaled range only affects a tags write value range and not the read value range.
If your scaled number is correct but you want to limit it, you can create a calculation tag which references the tag and limits the value.
The calculation tag expression would simply be:
//Example using tag absolute path
Limit([<path/to/reference/tag>],0,100)
//Example using relative path to parent tag
Limit([..],0,100)
The output would be similar to that below:
649b0b24ecf55
If you need to do this a bunch of times, consider creating a tag type for this. It's more effort up front but may provide some great experience and will be more efficient in the long run.
Sorry, the display range is for certain widgets but does not affect the tags read value. The scaled range only affects a tags write value range and not the read value range. If your scaled number is correct but you want to limit it, you can create a calculation tag which references the tag and limits the value. The calculation tag expression would simply be: ```` //Example using tag absolute path Limit([&lt;path/to/reference/tag&gt;],0,100) //Example using relative path to parent tag Limit([..],0,100) ```` The output would be similar to that below: ![649b0b24ecf55](serve/attachment&amp;path=649b0b24ecf55) If you need to do this a bunch of times, consider creating a tag type for this. It&#039;s more effort up front but may provide some great experience and will be more efficient in the long run.
