Unacknowledged alarms
Hello! I'd like to setup a digital alarm or status for ANY active alarms that are unacknowledged, and not shelved, that have been active and unacknowledged for 5 minutes or more.
Any direction would be appreciated!
Hello! I'd like to setup a digital alarm or status for ANY active alarms that are unacknowledged, and not shelved, that have been active and unacknowledged for 5 minutes or more. Any direction would be appreciated!
My solution to this will be the topic of our next Automation Village episode which you can check out here on July 6: https://youtu.be/8LKAKjEFWds
@ArghDave thank you for that answer! Very helpful and got me what I needed. Now to add on to that, question. Is there a way to run a report on historical alarms that were unacknowledged for more than 5 minutes?
To the best of my knowledge, you'd have to export the alarms and events data and then do some post processing on the times though I am not actually sure you will have all the info you need.
As a note, you can do this ad hoc by creating a filtered list of the alarm events you want to look at and then use CTRL+C and CTRL+V to copy and paste those events into excel or similar. This should get you started, once you have that, I believe that you can use ODBC or REST to create queries for the alarm events and process the timestamps from there.... Though no promises as I haven't actually done this.
To the best of my knowledge, you'd have to export the alarms and events data and then do some post processing on the times though I am not actually sure you will have all the info you need. As a note, you can do this ad hoc by creating a filtered list of the alarm events you want to look at and then use CTRL+C and CTRL+V to copy and paste those events into excel or similar. This should get you started, once you have that, I believe that you can use ODBC or REST to create queries for the alarm events and process the timestamps from there.... Though no promises as I haven't actually done this.
