Change widget that is diplayed in popup page via source code.
Is there a way to have a dynamic place holder to call a specific widget that is embedded in a popup page. i tried this but it does not link is there a specific function for this? Below is what i tried not the full source code just the specific areas.
Path = concat("WidgetInterlock", Replace(\GetPhrase(Taglink), 0, 12, "-", "_"smile);
GUITransform(12, 148, 579, 53,
1, 1, 1, 1, 1 { Scaling },
0, 0 { Movement },
1, 0 { Visibility, Reserved },
0, 0, 0 { Selectability },
Scope(\Code, "UserMethods", TRUE) \Path(\GetPhrase("FNK8JPMXx"smile
here is the code with the actual widget.
GUITransform(40, 156, 607, 61,
0, 0 { Movement },
Scope(\Code, "UserMethods", TRUE)\Widget_Interlock_P_440(\GetPhrase("FNK8JPMXx"smile,
Not sure why it added the smiley faces.
Is there a way to have a dynamic place holder to call a specific widget that is embedded in a popup page. i tried this but it does not link is there a specific function for this? Below is what i tried not the full source code just the specific areas. Path = concat("Widget_Interlock_", Replace(\GetPhrase(Taglink), 0, 12, "-", "_")); GUITransform(12, 148, 579, 53, 1, 1, 1, 1, 1 { Scaling }, 0, 0 { Movement }, 1, 0 { Visibility, Reserved }, 0, 0, 0 { Selectability }, Scope(\Code, "UserMethods", TRUE) \Path(\GetPhrase("FNK8JPMXx") here is the code with the actual widget. GUITransform(40, 156, 607, 61, 1, 1, 1, 1, 1 { Scaling }, 0, 0 { Movement }, 1, 0 { Visibility, Reserved }, 0, 0, 0 { Selectability }, Scope(\Code, "UserMethods", TRUE)\Widget_Interlock_P_440(\GetPhrase("FNK8JPMXx"), Not sure why it added the smiley faces.
edited Jul 12 '23 at 11:30 pm
Can you describe what you are looking to accomplish in a bit more detail?
Basically I want to be able to script in what widget is displayed in the popup page.
Can you create a parameterized page for this where the calling button provides an argument to identify the widget to show? Then your page script could have a statement or a simple calc on the visibility of the widgets which might be displayed.
