Mobile Browser Refresh Rate
How do I enable the permissions so I can update the value of the system tag "MobileBrowserAutoRefreshPeriod"? I can see it in the advanced view of the system properties but it is greyed out.
How do I enable the permissions so I can update the value of the system tag "MobileBrowserAutoRefreshPeriod"? I can see it in the advanced view of the system properties but it is greyed out. ![59d0438a839d5.png](serve/attachment&path=59d0438a839d5.png)
Just copy the setting. That default can't be changed but a copy can be changed and edited. If you have a copy with the same property name, the copy will be used.
The Anywhere Clients should show updates as soon as a tag value changes so it isn't that the page will only update every 60 s.
Just copy the setting. That default can't be changed but a copy can be changed and edited. If you have a copy with the same property name, the copy will be used. The Anywhere Clients should show updates as soon as a tag value changes so it isn't that the page will only update every 60 s.
