Report Tag - File Naming
Hi,
I am trying to use a report tag to create a standard report on a 24 hour basis, running the previous 12 hours of tag data into a csv file. I can get that to work.
But I want to further automate the process and I need VTSCADA to format the report in a certain way, so every day I want the current date formatted as DD-MM-YY followed by "raw".
I can get the report to output but it has its own name and format, how can I change this?
Thanks
Scott
Hi, I am trying to use a report tag to create a standard report on a 24 hour basis, running the previous 12 hours of tag data into a csv file. I can get that to work. But I want to further automate the process and I need VTSCADA to format the report in a certain way, so every day I want the current date formatted as DD-MM-YY followed by "raw". I can get the report to output but it has its own name and format, how can I change this? Thanks Scott
Suggestion that might help. I had a similar situation. I ended up having VTScada dump its csv reports into a folder in its default way. I then used windows task scheduler to trigger a batch file I wrote, once a day. The batch file manipulates the csv files, combining them, renaming them, and placing them in another directory.
This typically requires an excel template but can likely also be done using the scheduler and Microsoft's Power Automate.
Thanks for the replies, I've ended up just using the standard formatting than excel VBA to automate the collation of data into a formatted excel which is opened and ran by task scheduler.
105
