Simple Project
Hi,
I am the newone to VTScada.I want sample project which is better to understand.I expect simple project with procedure.
Hi, I am the newone to VTScada.I want sample project which is better to understand.I expect simple project with procedure.
You should start by watching: https://www.youtube.com/watch?v=lqK1yYnjQ_s&list=PLaEgD3YjzVRP8ZPBC7VizAQZBpbhZzpRF
Then check out the tutorial here: https://www.trihedral.com/help/Content/D_Tutorial/Tut_Overview.htm
Then try the LEVEL I – Operation & Configuration Course which you can download here: https://www.trihedral.com/training-courses
Let us know if you get stuck or have additional questions!
You should start by watching: https://www.youtube.com/watch?v=lqK1yYnjQ_s&list=PLaEgD3YjzVRP8ZPBC7VizAQZBpbhZzpRF Then check out the tutorial here: https://www.trihedral.com/help/Content/D_Tutorial/Tut_Overview.htm Then try the LEVEL I – Operation & Configuration Course which you can download here: https://www.trihedral.com/training-courses Let us know if you get stuck or have additional questions!
Hi,
I tried sample project.But Valve selector switch is not operated to open the valve.What is the issue?
Hi, I tried sample project.But Valve selector switch is not operated to open the valve.What is the issue?
Can you be more specific? Which of the samples are you working on and where in the tutorial are you having trouble?
