Anyway to require a note?
Is there a way to require an operator notebook entry when setting a value?
I have a bit that is used to bypass a process timer and would like to force the operator to enter a note when they use this. Currently I have an I/O and Calculations tag setup as a Digital[Out] and I'm using the Toggle Button to write a 1 to the bit when pressed.
I'm hoping to have it setup so when the operator presses the button, it requires the notebook entry and then writes the bit.
Thanks!
Is there a way to require an operator notebook entry when setting a value? I have a bit that is used to bypass a process timer and would like to force the operator to enter a note when they use this. Currently I have an I/O and Calculations tag setup as a Digital[Out] and I'm using the Toggle Button to write a 1 to the bit when pressed. I'm hoping to have it setup so when the operator presses the button, it requires the notebook entry and then writes the bit. Thanks!
24
