Tag Expression
Hi All,
I want to write three status from two different tag values.
"1" Means "Open"
"2" Means "Close"
"3" Means "Travel"
How to write the tag expression referencing another two tag value in VT SCADA.
if [Sludge Dewatering\ZIO_6333A]==1 then "1"
else if [Sludge Dewatering\ZIC_6333A]==1 then "2"
ELSE "3"
Hi All, I want to write three status from two different tag values. "1" Means "Open" "2" Means "Close" "3" Means "Travel" How to write the tag expression referencing another two tag value in VT SCADA. if [Sludge Dewatering\ZIO_6333A]==1 then "1" else if [Sludge Dewatering\ZIC_6333A]==1 then "2" ELSE "3"
While you don't have to, you may wish to use the ternary operator for this. Here is how you would format the statement:
variable = condition1 ? value1 : condition2 ? value2 : value3
This means that if condition1 is true, the variable will be assigned value1, else if condition2 is true, the variable will be assigned value2, else the variable will be assigned value3.
For your expression:
  [Sludge Dewatering\ZIO_6333A]==1 ? 1
: [Sludge Dewatering\ZIC_6333A]==1 ? 2
: 3
While you don't have to, you may wish to use the ternary operator for this. Here is how you would format the statement: ```` variable = condition1 ? value1 : condition2 ? value2 : value3 ```` This means that if condition1 is true, the variable will be assigned value1, else if condition2 is true, the variable will be assigned value2, else the variable will be assigned value3. For your expression: ```` [Sludge Dewatering\ZIO_6333A]==1 ? 1 : [Sludge Dewatering\ZIC_6333A]==1 ? 2 : 3 ````
So how we use the same expression in I/O tags? or I should use the expression in any other widget Properties.
edited Jan 19 '24 at 7:04 am
You'll want to create an I/O and calc tag. Put it into discrete calculation mode, enter the expression in the calculation location, and then write the value to the desired address.
There is too much there to fully explain in this post but we have lots of free training avaliable at https://home.academy.vtscada.com/
You'll want to create an I/O and calc tag. Put it into discrete calculation mode, enter the expression in the calculation location, and then write the value to the desired address. There is too much there to fully explain in this post but we have lots of free training avaliable at https://home.academy.vtscada.com/
Not sure if i understood correctly, but when I had to do something like this, i ended up nesting couple ifelse loops:
IfElse([<Sludge Dewatering\ZIO_6333A>] == 1, "OPEN", IfElse([<Sludge Dewatering\ZIC_6333A>] == 2, "CLOSE", "TRAVEL" ))
*Edit: if you gotta use numbers instead:
IfElse([<Sludge Dewatering\ZIO_6333A>] == 1, "1", IfElse([<Sludge Dewatering\ZIC_6333A>] == 2, "2", "3" ))
Not sure if i understood correctly, but when I had to do something like this, i ended up nesting couple ifelse loops: IfElse([&lt;Sludge Dewatering\ZIO_6333A&gt;] == 1, &quot;OPEN&quot;, IfElse([&lt;Sludge Dewatering\ZIC_6333A&gt;] == 2, &quot;CLOSE&quot;, &quot;TRAVEL&quot; )) *Edit: if you gotta use numbers instead: IfElse([&lt;Sludge Dewatering\ZIO_6333A&gt;] == 1, &quot;1&quot;, IfElse([&lt;Sludge Dewatering\ZIC_6333A&gt;] == 2, &quot;2&quot;, &quot;3&quot; ))
edited Jan 22 '24 at 1:59 am
261
