Site Map Context Tag - Data Age
Is there a way to move the Data Age from a polling driver that is a child to the parent Context Tag/Custom Tag type? i looked through the source debugger for a variable and could not find one. i am assuming this may not be possible with the default context site details widget that is displayed. And yes i know if the polling driver is the parent it displays automatically.
You can build your own communication widgets that reference the driver timestamps to construct a data age with expressions.
In my experience these values are not always reliable--in some cases they just do not update for a while even if valid data is coming in. It is much better to look at a proper watchdog timer from the controller or in lieu a rapidly changing process value (or combination thereof)
You can build your own communication widgets that reference the driver timestamps to construct a data age with expressions. In my experience these values are not always reliable--in some cases they just do not update for a while even if valid data is coming in. It is much better to look at a proper watchdog timer from the controller or in lieu a rapidly changing process value (or combination thereof)
edited Mar 1 '24 at 3:14 pm
Ya i have done that as well just wondering if it was as simply as adding something is the source file. Like how you can add \DisplayAddress to a custom type and it display whatever you program it to in teh tag browser.
196
