Report Tag
Hello, I am preparing a report, for this I want to bind it to a tag using the add parameter expresion to the duration value by selecting the time custom in the report tag, but it is said that I need to enter a value in the range 1-32767.
Can we make the I/O tag suitable for this. Obviously, I am creating the report time with the totalizer. I should somehow automatically assign this totalizer value as report duration.
Hello, I am preparing a report, for this I want to bind it to a tag using the add parameter expresion to the duration value by selecting the time custom in the report tag, but it is said that I need to enter a value in the range 1-32767. Can we make the I/O tag suitable for this. Obviously, I am creating the report time with the totalizer. I should somehow automatically assign this totalizer value as report duration.
We use this function alot - and have issues with it. Trihedral mentioned previouly that a fix is coming... I'm still waiting patiently...
See the below link on a temp fix - this works for us. Note that its better if you can have the parameter update only when you need it to, i.e. before the report runs, rather than every second (if that is what was planned).
https://forum.trihedral.com/index.php?u=/topic/1010/report-tag-duration-parameter-variable-problems/post-2560#post-2560
We use this function alot - and have issues with it. Trihedral mentioned previouly that a fix is coming... I'm still waiting patiently... See the below link on a temp fix - this works for us. Note that its better if you can have the parameter update only when you need it to, i.e. before the report runs, rather than every second (if that is what was planned). https://forum.trihedral.com/index.php?u=/topic/1010/report-tag-duration-parameter-variable-problems/post-2560#post-2560
Thank you for your support yes it seems to be working
78
