Numeric entry widget to write parameter of a tag
Hello, I am looking for a way to input a numeric entry directly into a parameter of a tag.
For example, I am trying to develop an interface for an operator to change the #highhighalarmsetpoint parameter of an IO/Calculation (Analog) tag.
The numeric entry widget is telling me the numeric entry is not linked to a tag (makes sense). Am I just using the wrong widget?
I am currently using the numeric entry widget to write to a separate IO/Calculation tag for the High High Alarm Setpoint, and set up an expression for the #HighHighAlarmSetpoint to read from the aforementioned IO/Calculation tag. Is there a better way to reference the parameters directly? Thanks!
Hello, I am looking for a way to input a numeric entry directly into a parameter of a tag. For example, I am trying to develop an interface for an operator to change the #highhighalarmsetpoint parameter of an IO/Calculation (Analog) tag. The numeric entry widget is telling me the numeric entry is not linked to a tag (makes sense). Am I just using the wrong widget? I am currently using the numeric entry widget to write to a separate IO/Calculation tag for the High High Alarm Setpoint, and set up an expression for the #HighHighAlarmSetpoint to read from the aforementioned IO/Calculation tag. Is there a better way to reference the parameters directly? Thanks!
Have you definitly linked the widget to the "seperate I/O calculation tag", and is that tag of type analog?
Attach a screenshots of the problem and we can probably be more helpful.
Have you definitly linked the widget to the "seperate I/O calculation tag", and is that tag of type analog? Attach a screenshots of the problem and we can probably be more helpful.
80
