VTScada Stops Logging Tag After Daily Backup via Task Scheduler
I'm encountering an issue with VTScada where a specific tag stops logging data after performing a backup to an external USB drive (C:\VTSCADA). This doesn't happen every time, but approximately once a week, right after the backup is completed, the tag flatlines. It's consistently the same tag that's affected.
For context, I am using a Windows script that only backs up files that have changed since the last backup.
Are there any known issues related to performing automated backups with VTScada files, particularly when writing data to an external device?
@echo off
:: Backup Folder 1
robocopy "C:\Users\NCID_\OneDrive\Desktop\Programs" "D:\Program Backups" /MIR /FFT /R:3 /W:10 /LOG+:"C:\BackupLogs\backup_log.txt" /NP /NDL
:: Backup Folder 2
robocopy "C:\VTScada" "D:\VtSCADA Backups" /MIR /FFT /R:3 /W:10 /LOG+:"C:\BackupLogs\backup_log.txt" /NP /NDL
:: End of Backup
echo Backup complete!
Are there any known issues with doing automated backups to VTSCADA files?
I'm encountering an issue with VTScada where a specific tag stops logging data after performing a backup to an external USB drive (C:\VTSCADA). This doesn't happen every time, but approximately once a week, right after the backup is completed, the tag flatlines. It's consistently the same tag that's affected. For context, I am using a Windows script that only backs up files that have changed since the last backup. Are there any known issues related to performing automated backups with VTScada files, particularly when writing data to an external device? ```` @echo off :: Backup Folder 1 robocopy "C:\Users\NCID_\OneDrive\Desktop\Programs" "D:\Program Backups" /MIR /FFT /R:3 /W:10 /LOG+:"C:\BackupLogs\backup_log.txt" /NP /NDL :: Backup Folder 2 robocopy "C:\VTScada" "D:\VtSCADA Backups" /MIR /FFT /R:3 /W:10 /LOG+:"C:\BackupLogs\backup_log.txt" /NP /NDL :: End of Backup echo Backup complete! ```` Are there any known issues with doing automated backups to VTSCADA files?
Good question, you a likely having conflits with files being open by several programs at one time. You need to use a file copy which supports Shadow Copy.
You may want to try looking into using ShadowSpawn along with robocopy to get around this (though I haven't looked into how efficient that will be vs simply using the built in Windows back-up feature).
Good question, you a likely having conflits with files being open by several programs at one time. You need to use a file copy which supports Shadow Copy. You may want to try looking into using ShadowSpawn along with robocopy to get around this (though I haven't looked into how efficient that will be vs simply using the built in Windows back-up feature).
