Script tag to Tag Browser
I have a script written where I'm talking to a Serial port sending and receiving messages.
Is there a way send the string response to a tag created in the Tag Browser?
I have tried using the following:
Scope(\VTSDB, "Com3\R_Status", TRUE)
Scope(\VTSDB, "h{zfoiw%7k\5dhe8xmq^m", TRUE)
It does seem to work a bit but ends up crashing VTSCADA.
Also tried it with LocalScope.
I have a script written where I'm talking to a Serial port sending and receiving messages. Is there a way send the string response to a tag created in the Tag Browser? I have tried using the following: Scope(\VTSDB, "Com3\R_Status", TRUE) Scope(\VTSDB, "h{zfoiw%7k\5dhe8xmq^m", TRUE) It does seem to work a bit but ends up crashing VTSCADA. Also tried it with LocalScope.
Did you try this? Sorry, have to upload as a pic since typing it out created a smiley face emoji.
6787bef51442f
Did you try this? Sorry, have to upload as a pic since typing it out created a smiley face emoji. ![6787bef51442f](serve/attachment&path=6787bef51442f)
edited Jan 15 '25 at 1:58 pm
Have you tried the set function:
Scope(\VTSDB, "TagName").Set("Variable");
Have you tried the set function: ```` Scope(\VTSDB, "TagName").Set("Variable"); ````
@mburns,
Please contact support to discuss the VTScada "crash" issue, the development team will want to find out what's happening.
Your question is unclear to me. Are you using a serial port tag or making a direct connection to the port, e.g. via ComPort()?
What is the tag that you want the response to go to?
@mburns, Please contact support to discuss the VTScada "crash" issue, the development team will want to find out what's happening. Your question is unclear to me. Are you using a serial port tag or making a direct connection to the port, e.g. via `ComPort()`? What is the tag that you want the response to go to?
@mburns would you be able to share the script for the serial comms - I've a device that needs to recieve text commands over serial and could do with some pointers? I'm not having any luck with SerialStream / SerSend etc.
160
