AB Micro820 Setup
Hi, Looking for advice on how to setup and import tags from a AB micro820. From the documentation about Miro820 tags there is reference to a address select tool. Where is this tool?
If i use the import tags function this results in driver not ready.
Not sure if i have the setup correct.
IP address 10.7.113.53
TCP/IP port 44818
PLC mode Micro820/850 Symbolic addressing
Port path [1,0]
Please can someone explain the correct setup for micro 820 to import analog and digital tags. Thanks.
Hi, Looking for advice on how to setup and import tags from a AB micro820. From the documentation about Miro820 tags there is reference to a address select tool. Where is this tool? If i use the import tags function this results in driver not ready. Not sure if i have the setup correct. IP address 10.7.113.53 TCP/IP port 44818 PLC mode Micro820/850 Symbolic addressing Port path [1,0] Please can someone explain the correct setup for micro 820 to import analog and digital tags. Thanks.
The documention that I can see states "The Address Select is not available in the Micro 800 series PLCs."
https://www.vtscada.com/help/Content/D_Tags/D_RockwellDriverTag.htm?Highlight=rockwell
If you get errors with the Driver/comms - try the port path [] - this has worked for me with a recent Micro820.
If you have alot of tags to create, you can edit the VTScada tags via Excel if you are comfortable with the formatting:
https://www.vtscada.com/help/Content/D_Tags/Dev_ImportExportTags.htm?Highlight=sync%20tags
The documention that I can see states "The Address Select is not available in the Micro 800 series PLCs." https://www.vtscada.com/help/Content/D_Tags/D_RockwellDriverTag.htm?Highlight=rockwell If you get errors with the Driver/comms - try the port path [] - this has worked for me with a recent Micro820. If you have alot of tags to create, you can edit the VTScada tags via Excel if you are comfortable with the formatting: https://www.vtscada.com/help/Content/D_Tags/Dev_ImportExportTags.htm?Highlight=sync%20tags
91
