What is the easiest way to do a daily pump run report for 5 years?
This is a question I was asked by a customer recently:
Q – What is the easiest way to do a daily pump run report for 5 years?
A – The built-in Pump Activity Report should work. It provides you with activity over the entire time frame, not daily over x years. You'd have to run it for the previous day and then have (5*365) = 1825 previous periods. Not allowing for leap years.
However, running it for 5 years will tie up the historian server for a long time especially if you include more than one pump. It would be better to run the report for a year at a time. It would be better still to run it month-by-month.
This is a question I was asked by a customer recently: Q – What is the easiest way to do a daily pump run report for 5 years? A – The built-in Pump Activity Report should work. It provides you with activity over the entire time frame, not daily over x years. You'd have to run it for the previous day and then have (5*365) = 1825 previous periods. Not allowing for leap years. However, running it for 5 years will tie up the historian server for a long time especially if you include more than one pump. It would be better to run the report for a year at a time. It would be better still to run it month-by-month.
21
