Serial Modbus - VTscada Light
I'd like to monitor, decode, and "interact" with a Modbus RTU device. Nothing complicated, I don't think. When I say interact the "linking" of meters/graphs to some of the registers etc would be really a nice to have and that seems to be inherent to your application.
Question:
Is VTscada Light the product I am looking for?
I reviewed the manual and looked at the software after installing it and could not see any serial physical layer instructions.
Can you point me in a direction or should I look else where.
I'd like to monitor, decode, and "interact" with a Modbus RTU device. Nothing complicated, I don't think. When I say interact the "linking" of meters/graphs to some of the registers etc would be really a nice to have and that seems to be inherent to your application. Question: Is VTscada Light the product I am looking for? I reviewed the manual and looked at the software after installing it and could not see any serial physical layer instructions. Can you point me in a direction or should I look else where.
Yes, VTScadaLight will get you going. The biggest restriction is that it will allow you to connect to up to 50 I/O. If you need more than that, you would have to purchase a license.
While we don't have a tutorial for specifically connecting modbus RTU, we do have several video tutorials to get you started which include connecting to a modbus TCP/IP device. Please check out the following links to get started:
https://www.trihedral.com/scada-software-video-tutorials
https://www.trihedral.com/documentation
Yes, VTScadaLight will get you going. The biggest restriction is that it will allow you to connect to up to 50 I/O. If you need more than that, you would have to purchase a license. While we don't have a tutorial for specifically connecting modbus RTU, we do have several video tutorials to get you started which include connecting to a modbus TCP/IP device. Please check out the following links to get started: https://www.trihedral.com/scada-software-video-tutorials https://www.trihedral.com/documentation
VTScada drivers use an independent Port tag to configure the physical connection and there is a "Serial Port" tag that can be used to achieve the connection you require.
The video tutorial referenced by Dave does use TCP/IP, but you can replace the TCP/IP Port with a Serial Port and then in the driver select the appropriate Modbus type for your device, ASCII or RTU.
See the help on Serial Port tags and Modbus Drivers.
VTScada drivers use an independent Port tag to configure the physical connection and there is a "Serial Port" tag that can be used to achieve the connection you require. The video tutorial referenced by Dave does use TCP/IP, but you can replace the TCP/IP Port with a Serial Port and then in the driver select the appropriate Modbus type for your device, ASCII or RTU. See the help on [Serial Port](https://www.trihedral.com/help/Content/D_Tags/Dev_SerialPort.htm?Highlight=serial%20port) tags and [Modbus Drivers](https://www.trihedral.com/help/Content/D_Tags/Dev_ModiconTags.htm?Highlight=modbus).
247
