Drive to widget
gps
I want a widget to drive to the site via long,lat that I can launch from the anywhere client.
I think this might help.
https://developers.google.com/maps/documentation/urls/guide
I've got an idea to try. BRB
I want a widget to drive to the site via long,lat that I can launch from the anywhere client. I think this might help. https://developers.google.com/maps/documentation/urls/guide I've got an idea to try. BRB
Ok, so I altered a program spawn like this,
  GUITransform(343, 23, 416, 2,
               Scope(\Code, "DrawingTools", TRUE)\ProgramSpawn("https://www.google.com/maps/search/?api=1&query=" + \Root\Latitude + "," + \Root\Longitude , "Drive"));
Now can I do this to a hotbox?
Ok, so I altered a program spawn like this, ```` GUITransform(343, 23, 416, 2, 1, 1, 1, 1, 1 { Scaling }, 0, 0 { Movement }, 1, 0 { Visibility, Reserved }, 0, 0, 0 { Selectability }, Scope(\Code, "DrawingTools", TRUE)\ProgramSpawn("https://www.google.com/maps/search/?api=1&query=" + \Root\Latitude + "," + \Root\Longitude , "Drive")); ] ```` Now can I do this to a hotbox?
I've updated my last comment to note that I just tested using links in the program spawn widget and it works fine. Therefore, you can simply use links to Google Maps URL's for each location.
copy something like:
https://www.google.ca/maps/dir//Trihedral+Engineering+Limited,+1160+Bedford+Hwy,+Bedford,+NS+B4A+1C1/
into the Program Spawn 'Program Path and Name' field.
I've updated my last comment to note that I just tested using links in the program spawn widget and it works fine. Therefore, you can simply use links to Google Maps URL's for each location. copy something like: ```` https://www.google.ca/maps/dir//Trihedral+Engineering+Limited,+1160+Bedford+Hwy,+Bedford,+NS+B4A+1C1/ ```` into the Program Spawn 'Program Path and Name' field.
edited Feb 20 '19 at 3:07 pm
It works on android!
Neat part is I got it to use the Longitude and Latitude from the Polling Driver!
Since most of the so-called addresses for lift stations are rarely good for GPS navigation.
It works on android! Neat part is I got it to use the Longitude and Latitude from the Polling Driver! Since most of the so-called addresses for lift stations are rarely good for GPS navigation.
edited Feb 20 '19 at 3:12 pm
115
