Screen size
When I RDP into the VTSCADA machine the window only fills half of the screen and cannot see the whole application. I can open other applications they work correctly and I can see the whole window. I don't think it is a RDP issue. Any thoughts?
After looking around the issue is i migrated the application to a different machine and the monitor resolution is different. How do I change the resolution settings so It will display properly?
If you open the 'Application Configuration' and go to the 'Edit Properties' tab you will find sections titled 'Application Window Behavior' and 'Application Window Size' which you can use to set your application settings. Note that pages can also have configured sizes which are set in the idea studio. These pages can be automatically stretched to fill the application window if you check the 'Stretch contents to fit available area' box in the 'Page Behavior' section of the 'Edit Properties' tab. I hope that helps. Note that for thin client use, you can also configure Realm Display tags to create unique settings for those connecting on alternate devices.
