Siemens S7-1500 series PLC with CP 1543-1
I am trying to connect to a Siemen's 1513-1 PN through a CP 1543-1 communications processor. When I do I am getting a value of 33,028 on my driver tag. 5cd42f67ca1eb
5cd42f67dbb7e
I am trying to connect to a Siemen's 1513-1 PN through a CP 1543-1 communications processor. When I do I am getting a value of 33,028 on my driver tag. ![5cd42f67ca1eb](serve/attachment&path=5cd42f67ca1eb) ![5cd42f67dbb7e](serve/attachment&path=5cd42f67dbb7e)
Is there a Siemen's driver error code list? In the manual I only see a 133, and 256 through 263.
It may be the GET/PUT but I would like to find out if there is a more comprehensive list of driver errors.
What actual version of VTScada are you using - 11.3.??
Those are the only errors we generate. Anything else is a pass through from the device.
What actual version of VTScada are you using - 11.3.?? Those are the only errors we generate. Anything else is a pass through from the device.
Can you check the Info button and see what the last part of the version is, please? There were a couple of changes to the Siemens driver and I just want to make sure you have them.
443
6
