VTS12 - Control Valve (Dynamic) Widget Show Units issue
Seems to be a little issue with the ShowUnits property on the Control Valve (Dynamic) Widget. If set to true the unit is "PercentLabel" if % or "hrLabel" if hr or "psiLabel" if psi or.... well, you get the idea.
Can you provide a bit more detail on the widget you are looking to draw? I can't seem to see a control valve widget type that supports unit display. I suspect this might be a custom widget and you might need to wrap the unit expression in GetPhrase() to show the value of the unit. Any more info you can provide would be helpful.
Hi Dave,
The Widget in question is ControlValveDynamic and is part of the Oil&GasSolutions layer. I've just ensured that I'm using the latest version (that I could find - 1.28.02). I'll place a ticket through appropriate channels....
This addition of \getphrase is understandable but is going to be a pain in the short term.
Hi Dave, The Widget in question is ControlValveDynamic and is part of the Oil&GasSolutions layer. I've just ensured that I'm using the latest version (that I could find - 1.28.02). I'll place a ticket through appropriate channels.... This addition of \getphrase is understandable but is going to be a pain in the short term.
Our engineering group manages that layer so I'll ask one of them to take a look at this. Thanks for the details.
Hi Dan,
We are in the process of working through upgrading the Oil & Gas Solutions layer to be compatible with V12.0 and will let you know when it's ready.
Hi Dan, We are in the process of working through upgrading the Oil & Gas Solutions layer to be compatible with V12.0 and will let you know when it's ready.
Lawrence MacNeil
Trihedral Engineering Limited
74
